Question about Sony Computers & Internet
Ports on EL3101 - Sony Computers & Internet
How to Change the Service VLAN to Which the xDSL Port Belongs
Changing the service VLAN to which an Huawei xDSL port belongs means changing the service port configuration, namely, the PVC configuration, of an xDSL port. To change the service VLAN, run the undo service-port command to delete the service ports (PVCs), and then configure a new VLAN for the Huawei xDSL port.
The prerequisites for deleting a service port are as follows:
When you specify parameters, all the matched service ports will be deleted.
A service port cannot be deleted in the following conditions:
The port is encapsulated as PPPoA, IPoA, or Auto.
The port contains the BTV user.
The port is bound with an IP address or a MAC address.
The port is configured with a static MAC address.
Huawei MA5600
Huawei MA5616
Huawei DSLAM
May 04, 2017 | The Computers & Internet
XBOX ONE CANNOT CONNECT TO THE INTERNET THROUGH WIRELESS ROUTER
my first guess would be you need to open ports in your firewall.
  • port 88 (udp)
  • port 3074 (udp and tcp)
  • port 53 (udp and tcp)
  • port 80 (tcp)
  • port 500 (udp)
  • port 3544 (udp)
  • port 4500 (udp)
Jan 21, 2015 | Computers & Internet
How to connect the network cable
you will have 8 ethernet ports in this switch... One port is for input all the other ports are for output...
If you dont have any dedicated uplink port, then any port can be used as an uplink port and other ports becomes downlink port...
The Lan slot of router should be connected to the uplink port in switch.... you can connect upto 7 computers in this switch(in downlink ports)...
Dec 13, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
In the board sata port is avaliable
No SATA port is not available with this motherboard, however there are 2 IDE ports available
Following is te details of he ports:
• Up to six USB 2.0 ports
— Four ports routed to the back panel
— Two ports routed to the USB 2.0 header
• Two IDE interfaces with Ultra DMA-33 and ATA-66/100 support
• One diskette drive interface
• One parallel port
• One serial port
• One VGA port
• PS/2* keyboard and mouse ports
Jul 17, 2010 | Intel D845GVSR Motherboard
Where is low side port for recharging a/c. on my 1997 s10. I found 2 ports one on the accumulator and one on the tube, however my charging kit port only fit the port on the accumulator. I assume this port...
The port on the accumulator is the low side. The high side port is smaller than the low side. The low side port is the one that gets cold when the compressor is running.
Apr 26, 2010 | 1997 Chevrolet S-10 Pickup
Is it possible to manage Cisco 585 LRE CPE remotely? Is it possible to monitor a Cisco 585 LRE CPE with i.e. snmp? Is it possible to remotely configure speed and duplex on either of the 4 LAN Switchports?...
blank.gifIF-MIB (RFC 1573) support for CPE Ethernet ports (read-only)
blank.gifRMON-MIB (RFC 1757) support for CPE Ethernet ports (read only)
These are the remote management options availible on this device.
Oct 02, 2009 | Cisco 585 LRE CPE (CISCO585-LRE) 4x10/100...
What do "ports" mean when adding printer?
An interface on a computer to which you can connect a device. Personal computers have various types of ports. Internally, there are several ports for connecting disk drives, display screens, and keyboards. Externally, personal computers have ports for connecting modems, printers, mice, and other peripheral devices.
Almost all personal computers come with a serial RS-232C port or RS-422 port for connecting a modem or mouse and a parallel port for connecting a printer.
On PCs, the parallel port is a Centronics interface that uses a 25-pin connector. SCSI (Small Computer System Interface) ports support higher transmission speeds than do conventional ports and enable you to attach up to seven devices to the same port.
In TCP/IP and UDP networks, an endpoint to a logical connection. The port number identifies what type of port it is. For example, port 80 is used for HTTP traffic.
Also see Well-Known TCP Port Numbers in the Quick Reference section of Webopedia.
Thanks for using FixYa - A FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 16, 2009 | Panasonic Toughbook CF-51 Notebook
I don't know how to remove "ports"
You need to specify exactly what you intending on doing. There is a difference in Port Triggering and Port Forwarding. If you are wanting to open a port on a machine you want Port Forwarding. There should be a place to specify a custom range of ports for any given computer on the network. Note that you cannot overlap ports (Cant port forward a port twice).
Dec 11, 2008 | Arris BR700 Router
Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Feb 06, 2008 | Cisco Catalyst 4006 Chassis ( 4006)
Computers & Internet Logo
29 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
