How to connect dvd player to esa tv model et427e.
Rca cable was tried but i dont know what channel or how to work.
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
To get signal by RCA cable to TV, you should select the TV input to AV. In most cases, you should have a remote control to select this input. Gopakumar Gopalan Google
Posted on May 14, 2014
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
Jun 24, 2014 | ESA ET427E 27" TV
ESA ET 427E 27" TV
what is the brand of your dvd player? ESA?
Jun 24, 2008 | ESA ET427E 27" TV
AV channel
Hi There. If you're connected to either AV input. (mostly RCA yellow, black and white receptacles), to by Scart, you must be able to switch your TV set to "External". There can be one or more "externals". F.i.
the ones described here: then you must be able to choose External 1 or External 2. There must be a button for this on your remote control.
Sometimes however, it goes by an menu. Choose Setup, or menu in general. There you'll find the way to select which input you want to use. So select the right one, then exit by the OK button.
Apr 19, 2014 | ESA ET427E 27" TV
I have a ESA 427E TV and no remote. I have a Philips dvd player. How do I get it to work with this tv.
Hi there. Connect the player by means of a SCART cable.
When you activate the DVD, the TV recognises this and goes automatically into AV mode. About the scart cable: take a fully wired type. Then pin 8 is at least connected. This status pin makes the TV switch to AV mode. (toggles between 0 and 12V)
In some cases, it's only possible to connect the signals by means of RCA connectors. (red,black, yellow). Then it's more complicated.
You have to use the local "channel" buttons on your TV. Press the (-) button a number of times until you reach channels below 1. That's were AV inputs are active. Good luck.
Feb 15, 2014 | ESA ET427E 27" TV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Remote control code for ESA ET427E 27" television
0053 worked for me on this exact model.
Oct 11, 2008 | ESA ET427E 27" TV
Need code for universal remote
yes i am lookin for codes for an universal remote. i have a rca universal remote and cant find no codes online for an esa tv
Jul 29, 2008 | ESA ET427E 27" TV
Input channel with no remote
You can a try another universal remote(some work wonders, others no so), or look through google, and you can find a replacement remote for your TV.
Jan 25, 2008 | ESA ET427E 27" TV
Eas tv model et427e
Using your TV remote (not the cable remote) use the input/select button to swtich to videe 2 or ? ; this should allow DVD to work/ when done use remote input/select button and switch back to video
Dec 23, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
