Question about NetGear DG834G Router
Connecting Ipod touch 8(GB) to Wi-fi
I have an ipod touch and a DG834G router, my ISP is AOL and I can't connect the ipod to AOL via the wireless connection. Everytime I enter the network settings manually the device says ( Unable to connect to network). Can somebody possibly offer a solution please!!!!!!!?????? I've eneetered the original network settings and followed solutions on the Apple website, ive even phoned Apple customer support and (after1.5hrs) they still couldn't figure out what the problem is.
I've entered the mac address in the routers allowed list, i've entered every IP address, subnet mask, router address and DNS server addresses, and no luck.
  • 7 more comments
  • Alex
    Alex Nov 05, 2007
    Yep I have the same problem with the same router - I've had my touch working without issue on an identically setup USR router. The touch will give an 'unable to join the network error' even when the SSID is broadcast and all security is fully disabled (wep & mac filtering off).
    Personally I think that the issue lies within the touch OS network driver as I have several other devices (pc, laptop, wii, ds, xbox ...) connecting just fine. A patch from either netgear or apple would be the ideal solution but I suspect not soon forthcoming - I would be interested to know if anyone knows of any work-arounds.
  • tuvok2560 Jan 15, 2008
    Thanks for the help folk, but the problem has know been resolved. The player itself had a malfunction and I sent it back to Apple who have since replaced it (excellent service). It works perfectly know, and I am able to connect to my router, for the record it works better on WPA-PSK2, with this router.
    Many thanks to all those who responded
    Tuvok
  • Anonymous Dec 13, 2008
    i just got an ipod touch and i dont know very much about it !!! i want to used the internet for itunes mail youtube but it keeps asking me a wi-fi network they are too of then linksys and netgear but it ask me for a password and i dont know what to put can you ppl help me !! ??
  • cesca200412 Dec 28, 2008
    i have recently got an ipod touch for christmas and it says enter my password to the wireless connector.. so i entered the WEP passwork at bottom of my wanadoo box and its still not connected?
  • damiangilles Dec 30, 2008
    I am having problems connecting the same router for wifi, with my i pod touch, sometimes the pod is asking for password other times it is not, very frustrating!!!! tryed James idea but still no luck!
  • Anonymous Jan 05, 2009
    exact same issue very frustrated
  • Anonymous Jan 17, 2009
    And they said this was easy!
  • thenerdarmy Mar 31, 2009
    i used to be able to get on to my network, but now it has stopped connected. It is a registered device on my computer, and it also comes up as an available network, but it wont connect to wifi..any tips?
  • fredpol_454 May 11, 2010
    tyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyypppppppppppppppppppppppppppppppppppppppppppppppeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee                      wwwwwwwwwwwwiiiiiiiiiiii----------------------ffffffffffffffffiiiiiiiiiiiiiiiiiiiiiiii
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Posted on Nov 05, 2007
  • lukeykerr Apr 24, 2011
    Thank you so much, this has been hours of frustration and this worked in a flash.
I have a linksys (now cisco) model WRT54G wireless router, and finally got it working with the ipod touch. Upgraded the firmware in the router by going to www.linksys.com and downloading it and installed it via the router's web based GUI. Wireless mode set to Mixed, Channel 6, set the network name, selected wpa personal security mode, TKIP wpa algorithm, and set the wpa shared key. Then it connected to it, but DNS didn't work, and it turned out my ISP had changed DNS server IPs and I had the old one specified in the list. (all other wireless devices worked OK with it, but not the ipod). When I removed the wrong DNS server IP address from the top of the list of 3 DNS server addresses, it worked.
Posted on Nov 07, 2007
I entered my WEP key as the password into the iTouch to get connected to the CISCO Linksys WRT110 router. The router was working for my laptop and desktop, but not for the iTouch until we entered the WEP key and it worked fine! My son is now online and accessing youtube, iTunes, etc. It took a while to figure that out!
The WEP key was also the problem when trying to connect our PS3 to the wireless router, so I had it on hand.
Posted on Dec 28, 2009
Booyah,
Alex1413 has the fix....Especially if you have a Netgear Router with WEP encryption...
Posted on Mar 31, 2008
Wow thanks alot Alex1414 this solution helped me after i spent over 1 hour and a half but finally i got through it.. i appreciate your great help.. big up!
Posted on Oct 17, 2008
Do this
Reset network settings by tapping Settings > General > Reset > Reset Network Settings.
Posted on Mar 07, 2011
I also have a Netgear DG834G router and had trouble connecting my ipod touch. Even with WEP or WPA disabled I received the ipod message 'unable to join the networ (SSID name)'
My solution was rather simple: I had forgotten that I had set up the MAC addresses of my other wireless devices as trusted wireless stations under 'wireless settings>wireless station access points' as an extra security measure. Obviously I had to add the ipod's MAC address to this list or turn off the access control via MAC address. It may sound a pretty obvious solution now that the wi-fi is working on my ipod but maybe there are some others out there who have also forgotten about the MAC address access control settings they have turned on. By the way the ipod MAC address is under Settings > General > About - then scroll down to Wi-Fi Address
Posted on Jul 15, 2008
Damn, thank you so much Alex1413. Your answer was the only one that worked for me, i've been trying to get my wi-fi going for 2 hours now.
Posted on Jan 14, 2008
Do what he said
Posted on Dec 20, 2007
I bought an ipod touch this morning and have had all sorts of problems getting on-line using my wireless network through a Netgear DG834.
The error that appears is the touch can’t find server – there are dozens of forum entries on-line with the solution – long story short : go into the control program of your DG834 (enter 192.168.0.1 into the browser bar) and make a note of your WEP encryption code key (usually 10 letters) – this is the numerical representation of your networks password, and it is based on a shorter digit/letter password.
When the touch asks for a password, don’t input the password, input the encryption code !!!
If you’re using encryption higher than 64 bit then again you may need to downgrade as the touch isn’t great at accepting WEP protocols.
Do the above and you’ll be on-line in seconds (assuming like me and most people you’ve got WEP encryption + good news is you shouldn’t need to re-code other PC’s or consoles (Xbox360 etc) on your network.
Good luck
Posted on Nov 14, 2007
I have a WNDR3700 and by adding the ipod touch mac address and when asked for password entered my WEP address and Key it connected immediatly.
Posted on Apr 15, 2010
Solution 5 worked for me - here's a virtual beer for you. Thanks
Posted on Mar 14, 2010
4 Suggested Answers
SOURCE:
  • 18 Answers
SOURCE: Connecting Ipod touch 8(GB) to Wi-fi
netgear support software could be bad. The ipod might not be able to read signal. umm try restoring the ipod. then plug it to your computer let it recognize it and then before you add ANYTHING to it, go straight to the setting and put in the router number and everythign and see if it works. I know people hate it but restoring it usually works. Its just simple small virus's that hit your ipod through songs and stuff and it eventually makes everything stop working. So get back at me let me know if restoring it worked.
Posted on Aug 14, 2009
  • 34 Answers
I want to tell you that there might be two problems for your concern.
1. Your router is not working properly
2. Your Ipod Touch is not working properly
But it might be possible that both devices working fine just the compatibility issue.
First of all i can suggest you that you can upgrade the firmware for your router.
Then you can reconfigure your wireless setting on your router.
Then tried to put static ip on your ipod touch in the network setting option
IP address: 192.168.0.15
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Primary DNS: 192.168.0.1
Secondary DNS: 4.2.2.2
Then tried again to connect wirelessly with your ipod touch make sure you dont required to add mac address for you ipod touch and also you can click on the option called "Wireless Access Point"
Then you can see the option " Turn Access Control On" you can uncheck this option.
Try again i believe that will resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Posted on Oct 28, 2009
  • 5 Answers
SOURCE: i need ip address,subnet mask, default gateway,
Try logging in to the router as admin and enabling DHCP.
Posted on Sep 26, 2010
My ipod touch is not connecting to the internet even though my wireless router is up and running
DEAR SIR, YOUR IPOD TOUCH IS NOT CONNECTING, IT MAY B THE REASON THAT UR IPOD'S WI-FI IS NOT WORKING OR SETTINGS OF WI-FI ARE NOT CORRECTLY DONE. KINDLY DO SETTINGS PROPERLY, IF NOT, THEN CHECK THAT YOUR ROUTER IS PROCESSING YOUR WI-FI OR NOT. THANKS. PLEASE RATE ME...
Feb 10, 2010 | Computers & Internet
Tip
How to Connect my Apple iPod Touch 8 GB to Internet
<p>Apple iPod touch is a touch screen version of its popular iPod device, similar in appearance and function of the iPhone. Like the iPhone, iPod touch is able to access the Internet, although by different means. While the iPhone usually connect to the Internet via a wireless network operator's mobile data, the only way to connect to the Internet in an 8 GB iPod Touch is the device to use built-in wireless adapter. <br /> <p><br /> <p>1. Get references to a wireless network nearby, if you are not home or do not have access to a public network without a password. If you're in a cafe, for example, ask the cashier to use the network password and you should use to connect. <br /> <p><br /> <p>2. Tap your iPod Touch "Settings" icon and "Wi-Fi." If a blue button "off" appears next to the Wi-Fi, tap it on the wireless adapter to connect the device. <br /> <p><br /> <p>3. Scroll through the list of wireless networks will appear, and then tap corresponding to your network. Enter a password - if the network requires - and tap "Connect" to your connection to the Internet iPod touch 8 GB. <br />
on Aug 05, 2011 | Apple iPod touch
Tip
How do I Connect my iPod Touch to a Netgear WNR2000 Router
<p>Netgear WNR2000, a wireless-N router, you can connect to the Internet without the hassle of cables. IPod touch supports Wi-Fi (wireless) connections. If you're within range of the router, you can connect to the wireless network. Once connected, enjoy a fast transfer speeds that allow you to quickly scroll pages and run the programs enabled network. <br /> <p><br /> <p>1. Connect the iPod Touch. Tap Settings on the Home screen settings of media player to start. <br /> <p><br /> <p>2. Scroll through the settings when you come to "Wi-Fi, tap to activate the feature. IPod touch detects networks in range. <br /> <p><br /> <p>3. Select the Netgear WNR2000 Wi-Fi network can include the name has been set, so it helps to know the name. If a secure network, enter the password. If you do not know the password, your iPod Touch cannot connect to the network. Once selected, your iPod automatically connect to the network. The Wi-Fi icon in the status bar at the top. <br /> <p><br /> <p>4. Select "ON" next "Ask to Join" if you want your iPod touch to ask you to connect to wireless networks within range. <br />
I can't connect my wi-fi to my ipod touch. My
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 23, 2010 | NetGear DG834G Router
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Sep 29, 2009 | NetGear DG834G Router
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
Jan 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
Thanks & Regards
Jan 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
sometimes the wifi systems only work with windows, the ipod only uses safari and thats what you see on the error. Its connected but safari cannot open it since it is not windows
Dec 13, 2008 | Computers & Internet
NetGear DG834G Router Logo
36,874 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
