Question about Dell Inspiron 1525 Notebook
Dell 1525 installed updates, computer re-booted on 3rd update says installing update but it will not and computer shuts down and restarts and continues doing the same.
  • Patrick Kam May 11, 2010
    Is your Dell 1525 a Vista trying to install Service Pack 1 or 2?
    If so, it will take you about 2 hours and a few reboots by itself.
    Tried Safe Mode to see is it doing the same?
  • 34 Answers
1. Turn off the computer.
2. Turn on your computer and start pressing the F8 key on your keyboard.
3. Select last known Good Configuration from boot Menu and press enter
4. This option should work but if it does not work try Safe mode option
Posted on Jun 23, 2009
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
Frozen on configuring updates...unable to restore or get to start
You must shut down and startup correctly not just unplug the power.Re-boot with ctrl/alt/del.
If your problem is serious,re-install OS,dont press any keys unnesessarily whilstb the reinstall is taking place--good luck!
Davey Snake!
Oct 21, 2010 | Dell Inspiron 1525 Notebook
Is overheating and shutting down, also the keyboard keys are sticking, sometimes I have to strike the same key twice
If the computer is restarting then it might be the FAN issue and FAN need to be replaced, but if the computer is shutting down then go to dell website, then go to driver downloads and update the BIOS then check weather issue perists..
Hope it will work!!!
Apr 26, 2010 | Dell Inspiron 1525 Notebook
Inspiron 1525 crashed during stage 3 configuration
Follow the instructions here to repair the OS, then manually install the update that causes the issue before enabling automatic updates
http://news.softpedia.com/news/Get-Vista-Out-of-the-Infinite-Reboot-Loop-Configuring-Updates-Stage-3-of-3-0-with-Vista-SP1-78933.shtml
Apr 03, 2010 | Dell Inspiron 1525 Notebook
Computer re-starts when i want it to shut down or sleep
You should check to see if there is a setting time where the computer installs updates, because the computer may be updating at a certain time and then restarts to finish the update. Check the setting to you might also have the computer restart every so often. hope that this helps.
Jan 08, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 laptop shutdown problem
The Laptop is not responding to the Software request sent to the BIOS or one is not getting there.
Best Solution is to make sure all of your Microsoft Updates are performed. Not just the Critical ones... but all that apply. You may see several hardware driver updates.
This will help the Software and Hardware to communicate with each other...
Jan 01, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
This morning i got a update for windows.. well!! i updated it and then a error screen came on.. i tried to reboot the note book but its stuck in windows boot manager screen.. my lap top wont shut down.....
Boot into safe mode then go to system restore and restore it to before the update or go to control panel and uninstall the update.
To boot into safe mode:
Right after bios loads up and before windows starts loading start hitting the F8 key
Choose safe mode with or without networking doesn't matter
Nov 09, 2009 | Dell Inspiron 1525 Laptop
Keeps coming up with configuring updates stage 3of 3 0% complete do not turn off your computer then it shuts down and comes back on again
Please use this solution thta I have placed on this forum.
Please follow exactly these steps then you computer should be working again.
I have used the following solution.
Restart computer.press f8 then choose option restore computer.
choose option open command.
type: prompt winsxs (press enter)
type: move C:\windows\winsxs\pending.xml text.xml (press enter)
type: exit and restart computer.
Computer should be working again.
good luck.
hope it works for you.
pieter.
Oct 17, 2009 | Dell Inspiron 1525 Notebook
My Dell laptop is stuck on Windows Vista Home Basic
Press F8 to go to Safe mode, open SYSTEM RESTORE to go back to checkpoint where not yet updated the system.
And next time to open back your system normally finished all updates before you shut down.
Sep 16, 2009 | Dell Inspiron 1525 Notebook
Will not boot up
hi there, check the cmost setup for hard drive detection. if detected you may have a software prob., try to re-install your operating system, i.e. windows, hope you can save your documents files before you can install new operating system. ty
Feb 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Inspiron 1525 Notebook Logo
111 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
