Question about Bosch HBL 755 Stainless Steel Electric Double Oven
Have double oven HBL 755 AUC error code F111 What is the problem. Thanks
Oven shuts off after 20 to 30 minutes. Seems to work ok till that point. Have had some luck trying to restart after letting it rest for a few minutes, but not always.
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
SOURCE: HBL 745 - stopped working
seems the oven was locked by the kids by mistake - found the manual and unlocked it.
Posted on Oct 16, 2008
  • 76 Answers
SOURCE: HBN 745 stays on forever
got a short in your switch
Posted on Dec 03, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch 755 Oven resets during cooking
Hi Jim. Thanks for your request re prob with your oven.
Unfortunately, this is not a problem I have come across before, so in this instance, I am unable to help solve it for you.
Only thing I can suggest at this time is that you check all connections and plug in connectors, you never know it could be caused by a bad or intermittent connection.
Once again, sorry I can't be of more help.
Posted on Jan 06, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
I need to download a manual for this product. Where can i find it?
I found a users manual for Bosch wall ovens at Retrevo.com
http://www.retrevo.com/s/Bosch-HBL755AUC-Ovens-review-manual/id/925ci470/t/1-2/
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
The doors on both ovens do not close tight. Are there replacement hinges? where can I get theme?
Same on ours... one seems like it is just softly lying against the gasket without a solid tight seal... doesn't bother the cooking much, it seems, but I hate little problems like this!
Will follow this thread to see if there is an adjustment for a DIY'er, without having to make a $120 service call...
I think the bearings have worn out on the fan in my oven,are replacement parts available?
We have the cooling fans in stock for the upper and lower ovens. Enter your model # at www.appliancehelponline.com. Select your part diagrams will also come up. All parts come with installation instructions.
Sep 18, 2010 | Bosch HBL 755 Stainless Steel Electric...
Only heats when door is open - if you turn on to preheat, nothing happens unless you open the door - the light and fan will be heard coming on, if you shut the door it all turns off
there is a microswitch on the door inner it sounds like its come loose or broken away affecting its operating tolerances should be easy to replace.
Feb 15, 2010 | Bosch HBL 755 Stainless Steel Electric...
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Door does not lock when set to self clean. Why?
HI. This will occur if the door lock mechanism is malfunctioning. This could be because of a failed connection, due to welded contacts, or a separated wring harness at the mechanism, or control board. Check these areas for faults. replace the door lock mechanism if all areas stated are ok, and connected well.
Oct 24, 2009 | Bosch HBL 755 Stainless Steel Electric...
Can i replace the oven light myself on the double wall oven,hbm43b550a ?
Yes your owners manual will show how.Replace the bulb with a similar bulb{ heat resistive}
Sep 28, 2009 | Bosch HBL 755 Stainless Steel Electric...
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 15, 2009 | Frigidaire 30 in. Electric Gallery Series...
I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
May 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Jan 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch HBL 755 Stainless Steel Electric Double Oven Logo
73 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
