Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Why does my lawn tractor shuts off - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
  • 2 more comments
  • Gary R. Kipfer Jun 03, 2014
    Hi John Bowe, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?When does it shut off, what is happening when it shuts off(turning,uphill mowing, ect)
  • John Bowe Jun 03, 2014
    I should have updated the post. I have two spark plugs and one wire was off. Reinstall the wire now works fine. I do have a push mower with the same problem. Starts right up then mowes for 5 minutes then sputters and shuts off. I wait for a few minutes and does the same thing. New spark plug, gas, sprayed with carb cleaner, clean air filter. Still no help. Any ideas?
  • Gary R. Kipfer Jun 05, 2014
    John when that old gas dries up inside the carb, it leaves a varinsh film on everything. Most of the time I have to take the carb apart to get it all clean
  • John Bowe Jun 19, 2014
    The mower started working for several mows but yesterday it stopped on me. I was mowing some tall grass then I was just riding on the mowed area when it started sputtering then shut off. I tried restarting it right away but it just turned over so I turned it off and looked at the fuel filter. I couldn't see anything in it or maybe a small drop about the size of a dime in the corner that is the lowest. I shook the filter and tapped on what I thought was the fuel pump. I closed the hood and tried starting it, it started right up. I drove up the hill to my house and almost at the top it sputtered and shut off again. I waited for a few minutes, started it back up and parked it in the garage. I haven't attempted to start it since. Shouldn't the fuel filter have gas in it?
  • Craftsman Master
  • 2,478 Answers
How your fuel cap vent?
Posted on Jun 17, 2014
2 Suggested Answers
  • 148 Answers
SOURCE: i cant shut off my lawn tractor with the key
I actually had the same problem with my tractor and it turned out to be that I had to run a second ground wire (ground to a separate point) that forces the coil to ground). My suggestion is to remove the flywheel cover and attach a wire (at a different point) to the coil and then start the tractor and when you go to shut it off. Turn the key and then just find a metal point on the tractor to touch the wire to and hopefully the tractor will shut off.
Posted on Jul 22, 2009
Another name for a coil
not sure what your asking does the tractor shut off or does the blade engage shut off or disengage?
Jul 28, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Jun 16, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Need a ramp that the tractor goes on top of to shut it off. broke mine
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Aug 25, 2010 | Nelson Sprinkler: Traveling Tractor
Sear ltv 10 varidrive lawn tractor
OLDER SEARS TRACTOR WILL NOT SHUT OFF WITH KEY. STARTS FINE.. ANY IDEAS WHAT TO LOOK FOR?
Jul 23, 2010 | Sears Garden
Fuel will not shut off accumulates in base of air cleaner on lawn tractor
needle valve is not seating right and needs to be replace. If you don't want to do that then the only solution is to go to a mower repair shop and get a fuel line cutoff . Cut the fuel line. insert the valve and shut it off whenever you stop mowing.
Jun 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor shuts off.
IF THE SEAT SWICH IS GOOD THAN THE BRAKE SWICH IS BAD
Oct 10, 2009 | John Deere Garden
My 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Sep 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I cant shut off my lawn tractor with the key
Jul 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
22 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
