Question about Singer 3116 Simple
Can I go from straight stitches to zigzag stiches and back in the same seam?
I am sewing binding on a blanket and I want to straight stitch to the corner, turn and zigzag back to continue around the blanket.
  • Susie Loew
    Susie Loew May 16, 2014
    Thank you for all the help. I was given this machine recently. I have been using 1950s Brother.
    Problem Solver:
  • 14 Answers
Yes, you can do it. Stop the machine, select your other stitch and then carry on sewing. Do not select another stitch with the machine running.It can become a expensive excercise.
Posted on May 16, 2014
    Champion:
  • 241 Answers
Yes all you have to do is stop with the needle in the fabric and pivot on the needle at the corner.. Raise the presser foot to allow the needle position to change as you select the new stitch. Then just continue with the zigzag stitch.
Posted on May 14, 2014
  • 4 Answers
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
Well, of COURSE you can! As a matter of fact, I often do that to baste something in place that I want to put a zigzag or decorative stitch on.
Posted on May 15, 2014
Elna 3007 reinforces every stitch.
It is in Stretch Stich mode....(SS)
Check your manual to reset in normal mode
Apr 07, 2014 | Elna Sewing Machines
My new Singer machine ("Curvy") purchased last week (3/2014) has a page on stretch stitches. The way the book is written, it lists Straight Stretch Stitch on the same page as Ric Rac, HOneycomb, and...
A zig-zag is also a stretch stitch. Usually, a "built-in" stretch stitch will stitch forward a couple and then stitch backward and then stitch forward again (time consuming and uses a lot of thread--but suitable if that's what you want). Whatever you are sewing, whether it is a seam or finished raw edge and the fabric is stretch, you will need to use a stretch or zig-zag. A straight stitch will pop the threads as soon as the fabric has to give.
You can test your stitches on some scrap fabric and see what looks best.
An Over-edge stitch is just that, just a stitch over the fabric edge. It probably would not be suitable for sewing a seam.
Apr 09, 2017 | Singer Sewing Machines
1249380 kenmore sewing machine
Depends on what stitch you intend to use. I do a lot of mending with a three step zigzag set to maximum width and minimum length -- see: http://www.picturetrail.com/sfx/album/view/24395076 A wide, short zigzag stitch is another popular choice, as is a straight stitch worked back and forth over the area: http://www.running-w-scissors.com/2014/01/tutorial-patch-mend.html
If you're just mending a seam that's come unstitched, a straight stitch or zigzag stitch similar to what's already in the seam is what you're looking for.
Feb 05, 2014 | Kenmore Sewing Machines
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Aug 19, 2009 | Singer Electronic Sewing Machine
Brother ls2125 won't zigzag stitch
that sounds like a timing issue if it will pick up every now and then i would recommend taking it to a brother dealer for repair as timing is not easy to set
Jun 22, 2009 | White Sewing 915
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Singer 3116 Simple Logo
197 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
