Question about SanDisk Electronics - Others
Sandisk com wug
My computer is not detecting USB Flash Drives
  • 289 Answers
Your laptop may need drivers installed for your flash drive. Visit your USB drive manufacturer's website, find the "Support" page, and download the drivers for your specific drive. Be sure to know what version of your operating system you are running as it may be necessary to ensure you get compatible drivers. Install the drivers and try again.
Posted on Nov 26, 2014
SOURCE: My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Posted on Dec 31, 2008
mastersaintx
  • 928 Answers
SOURCE: sandisk 4GB cruzer micro usb
Are you connecting it to the back of your computer? Sometimes the port in front does not have enough power to power it on.Also please try another computer
Posted on Feb 12, 2009
bob_computer
  • 3153 Answers
SOURCE: Sandisk Problame Unable To Open.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Jan 21, 2010
  • 10406 Answers
SOURCE: I have a SanDisk Cruzer
Take a router (wired or wireless), and use Ethernet cables to connect the two computers to the router.
Configure the old computer into the same "workgroup" as the new computer (and restart it).
Right-mouse-click on the folder containing the files to be transferred.
Click to enable "sharing" of that folder.
On the new computer, browse the "Network Neighbourhood".
It may take a few minutes for the new computer to "find" the old computer (working through the router).
Access the folder that you "shared".
Copy the files, over your private network, to the new computer.
Posted on Oct 03, 2010
bronk50
  • 27725 Answers
SOURCE: My pc is not detecting SanDisk Cruzer Micro 4GB US...
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
Posted on Jul 14, 2012
Www sandisk com wug
Amazon has many SanDisk micro SD options. Check the specs on your camera and search for "SanDisk MicroSD">
Aug 08, 2014 | SanDisk Electronics - Others
My flash dive is not work pc is not recognize it
Windows XP, Vista , or Windows 7 should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
If you have an older operating system then go here to download the driver:
http://www.sandisk.com/sandisk-support/driver-download-wizard
May 15, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My flash dive is not work.it can't do anything
But if you have an older operating system then go here to download the driver:
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Flash drive will not read?
Have you been able to get it to work on another computer? Have you formatted it? Check how many drives you have on your computer (i.e. c: d: e:) if you have many, then you may need to give your Flash Drive a new drive letter, see the following link: http://ezinearticles.com/?Flash-Drive-Not-Detected?-Solution-is-Here&id=1526594
Cheers.
Jul 09, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cant detect my flash drive
Have you tried installing the driver for it on your computer?
May 13, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 4GB cruzer micro usb
Feb 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Electronics - Others Logo
74 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
