Question about Yard Machines Garden
How to raise cutting hiegth ?
At its highest setting it cuts grass too low
  • Yard Machines Master
  • 2,413 Answers
I had a mower come in the other day like that and I just happened to have a set of four higher wheels that was off another machine I tore apart I put them on and brought it up where it should be.
Posted on Jul 19, 2015
  • 59 Answers
SOURCE: idles low, power loss, not enough power to cut grass.
check the spring on the carb
Posted on Jun 23, 2009
Bassplyr1
  • 77 Answers
SOURCE: WANT TO RAISE THE BLADES TO CUT HIGHER GRASS
There should be a lever with notches on each wheel to raise the mowing deck higher or lower. Make sure each wheel is the same height.
Posted on Jul 12, 2009
  • 168 Answers
SOURCE: fuel leak on craftsman pushmower with Honda engine.
Sounds like you tilted the unit enough to cause the float in the carb to open too much and therefore, the needle valve inside is stuck.
Remove the bowl and let it resit itself and then re install the bowl. If that doesn't work you may need to purchase a new kit for the carb to get the needle valve. If you find a small minut ring around the face of the needle valve replace it. That's why it's gonna leak. Good luck
Posted on Aug 02, 2009
  • 16 Answers
SOURCE: I have a 3 year old Toro 22
change the blade
Posted on Aug 20, 2009
riceski
  • 1851 Answers
SOURCE: 18" Electric LAWNHOG™ Mulching Mower from Black
Most likely the motor 'brushes' need to be replaced now.
These wear over time and most likely should be replaced by a professional.
Gary @ Fix Ya
Posted on Sep 05, 2010
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
wow, and you think we know what kind of mower you have ?!?!?!
May 14, 2014 | Yard Machines Garden
Troy Bilt zero turn Mustang Xp 50" deck height. My
raise the back as high as you like but unless you raise the front as well it will still cut short. If you want it higher and there appears there is no adjustment left you may have to re thread the adjusting screws to shorter dimensions or if it is on levers you may have to drill new holes further up the bars.
Jun 02, 2013 | Garden
Riding mower deck height too low
If you have removed the cutting deck for any reason you may have put the deck arms in the wrong knotch.
Apr 08, 2017 | Yard Man Garden
At the highest setting, I still cut the grass to short
The deck may be installed in the incorrect position on your tractor (if this is a tractor). If you have the owner's manual, check the information for installing the cutting deck. If not, then check the action of the lever and deck when raising it and lowering it, to verify it is working properly.
Jun 08, 2011 | Garden
I want to set the wheels for the deepest cut. In what direction should the wheels be adjusted-up or down?
If you move the wheels up, thereby lowering the cutting deck, it will cut the grass shorter on each pass.
If you move the wheels down, thereby raising the cutting deck, it will leave the grass longer on each pass.
May 04, 2011 | Garden
While mowing the grass the engine stalls and then catches back and stalls and catches back contuniually. the Murry select riding mower model number 405000x8c.
bad fuel filter, maybe cutting to fast, or grass is to high for what ever setting your at.
example. if grass is more then 10'' high, its not recommended to try and cut it to 3'' in one shot. start with the highest setting, and work it down. hope this helps.......
Sep 22, 2010 | Garden
Even on the highest setting, it still cuts too low. can i adjust it to cut higher?
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
Oct 15, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
The highest deck setting cuts my grass down to one inch.
leveling bolts hang from each side deck by frame...tightened up and level...will give you some more room....be sure the blades are not bent.
Jun 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
49 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
