Question about Irulu 4g 7"google Android 2.3 Touchscreen Tablet Pc Wifi 3g With High Sensitive 1080p
Is there a fix for getting the tablet to charge, connection seems loose.
2 Suggested Answers
  • 52096 Answers
SOURCE: The pin in the charging port is loose,and it hard to charge irulu expro1 tablet how can I fix this?
Google repair shops in your local area .
Posted on Aug 17, 2015
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
Apr 28, 2016 | Samsung Galaxy Tab 2 7.0
My tablet is not charging
Does the tablet power on when plugged in?
Have you tried a different power outlet, or a different power adapter?
Does the connector on the tablet seem loose or will the tablet charge if you hold the charging cable firmly to the charging socket?
Depending on your answers, it could be a bad charging port on the device, or a bad power adapter/cable, or a problem with electrical outlets. The remaining option would be a battery problem.
I post on behalf of HP.
Jul 01, 2015 | Tablets & eReaders
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
My charging port is broken or loose can't charge it . What are my options?
have you tried any other cables i have had problems with loose cable connections that were fixed by a new cable
Sep 08, 2013 | Craig CMP741d Tablet
I I dropped my samsung galaxy tablet with the charger plugged in. Now it will not take a charge. The green battery leitz does nothing while the charger is plugged in. I have an official samsung galaxy...
Hello, Mackenzie -
It seems that when you dropped your tablet something may have been knocked loose inside the tablet or something may have broken.
That means you will need to take your tablet to a reputable computer repair business in your area to have a repair technician check it out.
Usually for such repair evaluation services you will have to pay an initial inspection fee. The place where I take my computers and tablets charges $35 for an initial inspection and repair evaluation. Then, if the equipment can be fixed, they tell me the repair cost from which the initial $35 evaluation fee is deducted.
Note: In the future, after having to pay to get your dropped tablet fixed, you may choose to purchase a protective case for your tablet, to help prevent any damage from future accidents.
Jan 02, 2018 | Samsung Galaxy Tab Tablet PC
Battery not charging
Is it loose connection. or any problem with charger or tablet. give it to any service centres
May 24, 2013 | Samsung Tablets & eReaders
Display has lines and flickers. Better if the display is opened or tilted on its hinge ( has funky tablet hinge)
Press firmly down with your thumb on the laptop base just above the F4 / F5 keys, if the display improves while doing this it is simply a loose connection which is common for tablet pc's. If this does not help, then it is either a short in the connection or worse case an issue with what is called the inverter. In any case this is an issue that requires opening up your laptop to fix. If you are not comfortable doing this sort of work call up your local computer repair shop, I recommend a personal business over a corporate one, as you will receive better customer service and more likely than not if it is a simple cable connection issue small businesses will take a few minutes out of their day to fix it on the spot and charge you far less.
May 16, 2012 | Fujitsu LifeBook T2020 Tablet PC
Irulu 4g 7"google Android 2.3 Touchscreen Tablet Pc Wifi 3g With High Sensitive 1080p Logo
23 people viewed this question
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
