Question about Jenn-Air JFC2089HE French Door Refrigerator
How to correct/ adjust open freezer drawer that will not close?
Freezer drawer will not fully close
    New Friend:
  • 37 Answers
Shalom.
Uselly that will happen if something is in the way. Remove the food from the freezer and try the door. If it closes just put your food back and see if anything stiks out. If it does not remove shelves in the freezer and reassemble. Also check if the door seal is properly set.
Posted on Aug 21, 2014
  • 173 Answers
Check if anything is in the way
Posted on Jun 02, 2014
The LG freezer door does not close fully on the right side but seals perfectly on the left side, ideas?
I would check and see if the drawer is just stuck, or has something in it, or just remove the drawer and see if it seals
Mar 02, 2015 | LG Refrigerators
Why Bottom freezer drawer wont stay open
Freezer and refrigerator doors aren't usually supposed to stay open. The units are usually installed so that they're slightly tilted to the back to make sure gravity will close the doors if you forget to. If you are SURE - I mean really SURE - that you want your freezer to stay open you should check the drawer rails to see if they're adjustable; if they are, trying raising the back of the rails (or lowering the front). If the rails are not adjustable, try adjusting the front feet of your fridge so that the front of the whole unit is just a tiny bit lower than it is now. Don't lower it too much! If you do, the doors won't stay closed; they'll leak cold air and you'll lose food.
Jul 18, 2014 | LG LMX31985ST Super-Capacity 4 Door French...
Need gaskets for CSX20E Hotpoint side by side
Seals don't lose their magnetism. Check the door closes all the way round and adjust the hinges if it doesn't sit straight. Check there isn't a relief valve frozen up or blocked (it allows air to escape when the doors are closed). Check the drawers are fully pushed back in and not stopping the door closing properly
Sep 11, 2012 | Hotpoint Refrigerators
My refrigerator freezer door will not close.
Empty the freezer drawers and check they are all fully pushed to the back. Check the door alignment and adjust using the heel of your hand to straighten/ square it up. Check the magnetic seal makes contact all the way round.
May 29, 2012 | Whirlpool Refrigerators
Freezer drawer slides
you have to keep the white wheels on the rod even or the draw won't close correctly,pull the racks out fully open and even on both sides,you might have to adjust the wheels so both sides are even,i use a marker and mark the wheels,now when you hook the door assy on.you have to make sure the wheels stay in place or when you close the whole unit one side of the door won't close all the wa,it's a little tricky if you never tried to line them up before but if you mark the wheels part numbers 12002497 so both sides stay lined up it will close correctly. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2560HES/3048/0161000/M0412077/00009?blt=06&prst=0&shdMod=MFD2560HES this is the sears site and will show you a picture of all the parts.hope this helps
Dec 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
The Freezer drawer on our new LG LFC25776W is sticking shut. We have tried unplugging the fridge and letting it fully defrost at which point both the main door and interior slide shelf work fine when at...
Sounds like you have a clogged drain or partial. Pour hot water down the drain underneath back panel; until it takes the water without running over.
Check temp in freezer. It probably is freezing the water in the drain.
Temp should be between 0 to 10 Degrees.
Jul 20, 2011 | Refrigerators
Meat and vegetables placed in the produce drawers turn to ice. fridge temp set at 39. freezer set at 0. as you face the fridge, the drawer on your left is the worst. fruit is okay in right drawer.
check the damper door vent assembly located between the freezer and refrige compartments and make sure its not frozen open so as to let cold air in all the time,adjust the temp in the refrige and the door should open and close with adjustments,if not then damper door motor assy or the electronic control board is defective that supplies power to this door
May 13, 2010 | GE PDS22MCR Bottom Freezer Refrigerator
Sub Zero Model 550 (1992) freezer drawer doesn't seal
the drawer need to be adjusted so that it will close.. with a air leak you will have frost build up around the drawer...there are drawer closers on the back of the rails... it may be broken or just pushed the wrong way...when the freezer is cold it should make that sucking sound and be hard to open ... hope it helps
Sep 19, 2009 | Refrigerators
My freezer opens by itself after we close the fridge what can cause this
Is the refrigerator sitting on a level floor?
Are the freezer door or racks overloaded with food/packages such that the packages push the door back out?
Are any roll out drawers to full to fully close, including if something has fallen down behind them?
Jan 15, 2009 | Refrigerators
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jenn-Air JFC2089HE French Door Refrigerator Logo
253 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
