Question about SCOSCHE Cell Phones
How to change the langauge on the boomBottle
Ive had the boomBOTTLE pluged into my laptop, with the auit cable. ive come to unplug it and turn it off and its started speaking french..... anyone help
SOURCE: toyota previa misfiring
It sounds like the rotor button is not making a good connetion. i recommend replacing the distributor cap and rotor button to be safe. It is a cheap solution.
Posted on Jul 16, 2008
ShinyTechie
  • 15 Answers
SOURCE: No sound from internal speaker Hp laptop
I recomend you check the soundsettings for output devices in the controlpannel first, and try reinstalling the audio driver and updating the BIOS. If you want to be 100% sure its not a software problem you can also a full system recovery. You can start it by pressing F11 at the HP logo during boot.
But since this happend after you used the audio pass through board, that is the most likely cause. If you are comforteble opening the notebook, you can check this by disconnecting it. If the sound comes back on the internal speakers after disconecting it, it will need to be replaced.
Else, if the powerbutton does not light up(it should when you turn on the unit) it is a defectice PBB cable. But even if it lights up it doesnt rule out that the cable is defective. If the quickplay touchbuttons are sett to give a beep when pushed, you should check if they still do. if not it strengthens the probability of the defective cable.
This can also be a defective mainboard. But this is a very rare mainboard problem on these models.
If the unit is out of warranty and you want to replace the parts yourself, I can provide you partnumbers. But i will need the modelnummber form under the unit. It should be written on a small whtie lable and look something like this AA111BB#CCC.
Posted on Mar 13, 2009
SOURCE: i have a goodmans gmp38g6
read the manual
Posted on Jun 21, 2009
SOURCE: can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
Posted on Dec 11, 2009
  • 42 Answers
SOURCE: my furbys voice wont work.
You would have to take a look inside and make sure wires are ok. Could simply be a lose wire to the speaker sort of deal. Hope this helps
Posted on Mar 27, 2010
I have a older square black scosche speaker how do I turn on the pairing it to my phone
How to pair the boomBOTTLE+ portable speaker ' Scosche
www.scosche.com/.../how-to-pair-the-scosche-boombottle-portable-spea...
Sep 16, 2015 - How To Pair The Scosche boomBOTTLE+ Portable Speaker ... Turn on your device's Bluetooth Menu to search for and connect to the boomBOTTLE+. ... only one speaker, place the speakers in "S" (stereo) position and turn off ...
Scosche ' Products by Scosche
www.scosche.com/blog/
Jan 01, 2016 | SCOSCHE Car Audio & Video
Has a short in charging ...where can I get it repaired??
check with the manufacturer .perhaps they have a website and tech support
Jul 14, 2015 | SCOSCHE boomBOTTLE
Fixing color on moitor
sir please change or plug and unplug your VGA cable.
Oct 09, 2012 | Compaq crt monitor v570 - display - crt -...
My iphone wont turn on ive been trying holding the on button and home button ive tried pluging it in the computer when i hold both buttons down at once the apple logo appears but then goes straight to a...
your computer may not be recognizing iphone.if you have 110 volt sync cord adapter, see if you get the battery icon.if it does start charging, you may have to delete itunes and reinstall( or upgrade)
Jan 19, 2010 | Apple iPhone Smartphone
No picture on tv screen when i turn on my 360 plz help
make sure the hd switch is not turned on on the video cable that connects to the xbox, it is a small black switch
Jun 28, 2009 | Microsoft Xbox 360 Console
I turn computer on and power light and reset light both on but green motherboard light is not on. keyboard is frozen with no lights on, mouse has optical light on but screen is sayin no vga inpput detected...
U CAN unpluged your video card and then u clean the slot with brush....or tissue maybe...after that u insert video back to the slot (pluged on).
Jun 05, 2009 | Computers & Internet
H700 wont do anything
I think the charger is the problem. I ordered one of these and then it wasn't charging the day I got it....it's supposed to go from red, to orange to green as it charges, but the red LED just goes off after a while, before the headset is fully charged. I solved this by charging it through a USB-to-miniUSB cable on my laptop USB port. This worked beautifully....unfortunately I think the H700 chargers are faulty.
Feb 09, 2009 | Motorola Mobility H700 Wireless Headset
My Compaq PC says disk boot failure and asks to insert system disk. However, having had my pc for a few years, I have misplaced my sytem disk.
Check the bios to be sure that it sees the hard drive and if it does not then
Try (with the power off) unpluging the data cable from the hard drive and then pluging it back in then turn on the computer and see if it sees the hard drive. If it does and still no boot then its like the person said above and your boot sector is probably corrupt and you will need to boot with an xp cd to the recovery console and type this at the command prompt: FIXMBR and then type FIXBOOT then EXIT but try the unplugging the data cable and plugging it back in first..
Ive seen that problem several times and unpluging the cable and pluging it back in sometimes fixes it
Nov 23, 2008 | Computers & Internet
Green light on no display
My lg lcd turns on but does not display picture and every now and then after ive unpluged and pluged it in a few times displays a series of coulours down the screen i try changing the inputs but it still stays with the coulours anyone have the some problem?
Oct 29, 2008 | LG 42LC2D 42 in. LCD HDTV
Cell Phones Logo
93 people viewed this question
Top SCOSCHE Cell Phones Experts
William Alequin
Are you a SCOSCHE Cell Phone Expert? Answer questions, earn points and help others
