Question about Exercise & Fitness
How can I stop it from being very squeaky and noisey ?
When I'm using it ,it makes heaps of squeaking noises coming out from where the crank arms are connected to the drive belt .
pal03246
  • 726 Answers
SOURCE: Squeaky noise from belts.
nissan has an updated belt tensioner and it will also get a new belt.
Posted on Jul 23, 2008
MNTECH
  • 1543 Answers
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Posted on Nov 18, 2008
  • 1861 Answers
SOURCE: squeaky noise from serpentine belt
Replace the serpentine belt tensioner. Expect to pay approx $150.00 if installed by a mechanic.
Posted on Dec 29, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Unit making loud squeaky noise
http://www.youtube.com/watch?v=7n5tywSdWKs
This is a cool video with link to applience parts for help and answers
Posted on Feb 02, 2009
SOURCE: Universal Joint
04 Ford F150 seems to slip into drive from park
Posted on Apr 29, 2009
Squeaking noise when applying the brakes,have had the brakes serviced and cleaned 6 times, and still have noisy brakes.
its sounds like the shims where not installed on the brake pads like they should of. or the pads are glazed from overheating
Mar 07, 2011 | 2009 Volvo XC90
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
Loud squeaky rear wiper on a 2000 odyssey.
Before you go through the time and hassle of removing the motor itself, spray some WD-40 or something similar on the shaft that goes to the motor...could be the weather seal is dried and squeaking.
Dec 13, 2009 | 1999 Honda Odyssey
Very squeaky belt or pully, use to stop when gas pedal applied but now squeaks when gas pedal applied and most idle times. Been using wd40 but doesn't work as good now
1999 probably has a serpantine belt (multi grooved). I would guess that you may have a squeaky belt or more likley a bad bearing in on of the idler pulleys. Remove the belt and spin the idlers by hand. If one feels rough or makes noise replace it.
Sep 24, 2009 | 1999 Dodge Caravan
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeaky noise
hi,
that squeaky noise is the sign of the compressor mechanical parts problem. a sign of compressor replacement.
Nov 24, 2008 | U-Line Refrigerator Ice Maker
Squeaky Door on GE Arctica Refrigerator PSC23NGMB
Use Vaseline on the cam where the plastic slides across onother surface when opening door.
Nov 13, 2008 | Refrigerators
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
