Question about Frigidaire Washing Machines
Frigidaire model fex831fso
Fill with water but does not agitate or spin belt is ok motor does not run
    Problem Solver:
  • 6 Answers
Can you hear motor trying to run if so . there are 2 things to check agitator has a mechanical device that when it spins it grips the agitator and starts to spin . its like a coupling . also the motor two ha a direct coupling attached to gear box both items are made of plastic in time they do break down . but if you motor runs on a belt and does not run then does it work in wash cycle if so motor ok but selector switch not working properly. if both cycles don't work motor start winding has burnt out can you smell burnt insulation around motor if so need new motor . if thi does not help you google you washer machine on line and you might get a break down on what other possible cause that could effect you washing cycle . but google brand and model number of washer.
Posted on May 14, 2014
Testimonial: "thanks for info. motor don't smell burnt timer cycles fine fills and drains wont wash or spin motor doesn't try to kick in I bypassed lid switch and thermo switch no change do you think it could be the motor thanks again for any help"
  • Nick C May 16, 2014
    well im a sparky with out testing with meter i can not answer that question. hate to say yes then you buy motor and install it and it still wont work . do you have a sparky mate that he could look at it? if not well then you will have to call a service man.
    Habit-Forming:
    New Friend:
  • 70 Answers
Check the door interlock switch Diagram enclosed There is also some other interlocks High limit Thermal, Motor cradle
Good Luck Rickie
catriver
  • 878 Answers
SOURCE: Washer will not spin nor agitate
mj, sounds like a broken coupler, look at number 13 on the picture. The fact that it won't agitate or spin but will drain rules out the lid switch. This is not a hard job. Check this out first. Catriver..post back
Posted on Apr 02, 2007
catriver
  • 878 Answers
SOURCE: washer will fill up with water and drain but will not spin or aggitate. the model is kitchenaid kawe677bwh1
Rick, for the posted model. This is a direct drive washer, no belt. As long as you are draining, I believe you have a broken motor coupler, about a 19.00 part. Check out the attachment, look at # 13. One end to the motor, the other to the trans. You will have to remove the cabinet, pump and motor to get at it. Easy job. Catriver.
Posted on Jun 17, 2007
abhishek33
  • 1239 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Posted on Jan 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
Posted on Apr 25, 2009
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
I have a frigidaire heavy duty extra large capacity 2 speed combination 3/4 horsepower.washer dryer. The washer fills,drains and spins. It does Not agitate. I can spin the tub counter clockwise. The thingy...
Hello Marjorie, thank you for your post!
From the information you have provided water will fill, drain and spin but your Frigidaire washer is not agitating. This could be a problem with your motor, belt, or pulley. Locating the problem is not a simple DIY job and I would suggest seeking assistance from a professional. They have the appropriate tools needed to disassemble your washer and prevent any future issues. I hope this information is helpful to some degree. -Matt
Mar 10, 2015 | Frigidaire Washing Machines
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
Oct 25, 2011 | Washing Machines
Fills with water..doesn't wash..drains and spins..does the transmission spin in direction and wash in the other? in other words does the motor run one direction to spin and rev. to agg/
Yes it does reverse. If the motor is running in agitate pull off the agitator and check the agitator drive (bell) (white plastic bell shaped) on top of the agitate shaft is not stripped. You should not be able to turn. To remove the agitator fill first about 8 in of hot water, drain and pull up on agitator with fingers under the bottom or a belt.
Nov 22, 2010 | Hotpoint -Ariston VVSR1030HWO Top Load...
Does not agitate or spin
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Jun 20, 2009 | GE Washing Machines
Fills with water but won't agitate
There is a plastic coupling that connects the motor to the transmission. They very commonly break. If you google frigidare washer parts, you can easily find a parts breakdown. Cheap fix.
Jun 04, 2009 | Washing Machines
Will not spin water will fill but its not spining i
Hi, Could I get the model # so I can see the exact washer you have?
Does this washer agitate at all? Dose the motor run but no spin?
Please let me know so I can assist you further.
Thanks
Vic
May 31, 2009 | Kenmore 22422 Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
137 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
