Question about Acer Aspire 9410 Notebook
Why will my Acer Aspire 9410 not boot up
When I switch my Aspire 9410 all I get are beeps one long & 4 short.
    Top Expert:
  • Acer Master
  • 8,248 Answers
Could be faulty ram or over heating fan probs
Posted on Mar 29, 2015
  • 70 Answers
SOURCE: setup password lost in an Acer Aspire 9410 laptop
The best way to this is to reset the cmos on the motherboard of the Laptop. This will reset the bios password.
To do this unplug all power from the unit and remove the battery. Remove the cover from the laptop so the motherbard is exposed. Look for the cmos battery (about the size of a nickel) and remove the battery for about 30 mins and then replace. Reassemble your laptop and you should be good to go.
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: orignal battery for acer aspire 9410
Go TO acer shop it will give u battery free original
Posted on Apr 21, 2009
  • 83 Answers
SOURCE: Laptop freezes shortly after boot up. Acer aspire
check the model manuals to enter safe mode and recovery options from BIOS mode
Posted on Sep 02, 2010
bronk50
  • 27725 Answers
SOURCE: my acer aspire one beeps when i switch on 1 long 2 short and wont power up
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk, and remains active until turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive SATA
Make sure they have a secure dust free connections.
Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it.
Restart your computer the found new hardware wizard should activate.
Hope this helps.
Posted on Nov 27, 2012
SOURCE: Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Posted on Dec 08, 2012
Orignal battery for acer aspire 9410
Apr 21, 2009 | Acer Aspire 9410 Notebook
Acer Aspire 9410 Won't work with two memory slots filled
As you mentioned that you want to use Maximum memory that is supported by 9410, I would like to tell you that you have 32 bit processor in your notebook as its not always advisable to use 4 GB RAM with 32 bit processor as we have seen lots of compatibility issues.Infact in 32 bit processor windows will typically report only 3.2 GB due to a limitation of windows itself.
Mar 25, 2009 | Acer Aspire 9410-4317 Notebook
Setup password lost in an Acer Aspire 9410 laptop
Feb 24, 2009 | Acer Aspire 9410-4317 Notebook
Bios password acer aspire 9410 Notebook
hi im josh in cebu phils. if the you forgot the password then you can delete or changes it. you go to the bios utility setup then go to security settings then disable or change new password.then save the changes then reboot your pc. bang! problems solved.good luck
Feb 23, 2009 | Acer Aspire 9410-4317 Notebook
Acer aspire 3000
HERE is a link to the repair guide for the Acer Aspire 9410. With this, you should be able to find the correct method or removing the original keyboard and replacing it. If you have a replacement from Acer, you should have been given instructions on how to replace it manually.
Dec 20, 2008 | Acer Aspire 9410 Notebook
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Acer aspire 9410-4933
Hi, Cant answer your first question but i can for question #2. boot from the windows vista CD and run startup repair. that should fix the problem.
Oct 02, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 9410 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
