My washer started beeping con't and won't turn on or work. i pushed the cycle signal button an the beeping stopped . it still won't turn on. WHAT CAN I DO? IT SOUNDS LIKE IT HAS WATER IN IT STILL.
Mod WTW6800WW1 type 580 ser CY5070497
  • Washing Mach... Master
  • 16,010 Answers
That model is a top loader. You should be able to see if it has water in it. The first thing to do is unplug it for a minute and see if it resets.
If it does not, you can drain it by taking the drain hose out of the house connection and lowering it and letting gravity drain it. You can also use a wet and dry vacuum to pull the water out of the drain hose. When it is drained you can then lay it down and check the pump and trap to make sure that it is clean. If it is then the problem is related to sensors or control board.
Posted on May 14, 2014
jsrock516
  • 5911 Answers
SOURCE: Cycle Signal Won't quit beeping
This is a common problem with the Oasis. The problem is with the interface control board in the console, and/or wiring harness to the board. I have repaired three of these problems in the last 6 months and it was the interface control board each time. The machine will still function normally except for the annoying noise. I don't know of an easy way to defeat the noise functions to the interface control board, or if it should even be attempted. You could cause more harm than good. It can be a bit pricey to replace, and can be tedious to remove. If you wish to attempt to repair, let me know and I can give you some step by step tips on how to remove.
Posted on Jul 18, 2007
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
Posted on Mar 14, 2008
SOURCE: washer stops and start button blinks
The solution is pretty simple. there is a filter located right before the water pump.
* Remove the lower panel (lower as if you were looking at the front of the machine)
* Remove the 3 screws (it is easy if you have the lower drawer unit .. you will have to 'get low' if you don;t have it)
* You will see a 3" cap right facing you (in the center)
* GET A POT. and place it below the cap (foul water will come out when you remove the cap)
* remove the cap (finger tight)
* I found coins, hair, lint, dollar bills .. etc (about the size of a roll of cookie dough)
* Take CLEAN water and dump it into the washing machine (this will clean out the tube/hose)
* replace cap
* run machine BEFORE you put the cover back on (make sure it doesn;t leak)
* replace cover/screws
Posted on Jul 09, 2008
jsrock516
  • 5911 Answers
SOURCE: help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Posted on Aug 27, 2008
  • 464 Answers
SOURCE: Hello, my washer won't run! Whirlpool Cabrio
make sure the water inlet valve to the machine where the hoses hook up is in good working order. if you don't get water in the machine will lock you out.
Posted on Oct 16, 2009
Testimonial: "this seems like helpful advice on the surface, but after looking up the error code I'm receiving it is something to do with the motor rotor sensor..."
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
To Enable or Disable the Cycle Completion Signal...
1. Open the door, hold down the “Quick Wash”
button and simultaneously turn the Dishwasher on.
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it
doesn’t beep, it means that the Cycle
Completion Signal has been disabled.
3. Turn the Dishwasher off to take it out of
program mode.
I hope this answer's your question. Thank you for choosing "fixya".
Please rate the solution favorably if indeed it was helpful, if not please let me know.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Trouble starting Cycles
Jonsey, sounds like you have a keypad issue here. Do this test: press the following keys in this order soak-cycle signal-soak-cycle signal. If done right the display should show dt. Now press start, all the led's will light up. Now test them by pressing each one, you should hear a beep for each one. If some of them are not responding, check the P-11 and P-12 harness on the control board. You can also put this machine in the automatic test mode by pressing the keypads in this order; soak-soil level-soak-soil level. The display will start counting down from 99 to 0 testing different aspects of the machine. Any errors will be shown in the display. Catriver..post back.
Nov 13, 2006 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
