Question about Garden
What is the Compression for a 1985 Harley Davidson 1000 cc sportster?
  • Garden Master
  • 16,373 Answers
Are you asking what a compression reading should be or the compression ratio? If you are troubleshooting then you should use a cylinder leak down tester. It tells you alot more about the engine.
Posted on May 14, 2014
Aligning crankshaft marks
Camshaft timing procedure for 1982 harley davidson xlh 1000 cc
On the pinion gear there is a timing mark.
This mark will line up with the rear cylinder intake cam.
There are 3 marks on this cam.
One will line up with the mark on the pinion gear.
One other mark will line up with rear exhaust cam and the front mark on the rear intake cam will line up with a mark on the front cylinder intake cam.
The front intake cam also has a mark on it that will line up with the front exhaust cam.
http://www.downloadninjas.info/harley-davidson/1986-2003-harley-davidson-sportster-xl-xlh-service-manual/
http://www.downloadninjas.info/harley-davidson/2006-harley-davidson-sportster-xlh-service-manual/
Jul 30, 2013 | Harley Davidson XLH 1000 Sportster...
General Info on a 1979 sportster XLCH 1000
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson XLH 1000 Sportster 1979
Sep 09, 2012 | 1979 Harley Davidson XLH 1000 Sportster
1985 sportster 1000cc cylender torque specs
Hi Anonymous, in a criss cross pattern and your torque specs are:
1. 1/4" bolts 10 ft lbs.
2. 5/16" bolts 20 ft lbs.
3. 3/8" bolts 35 ft lbs.
4. 7/16" bolts 55 ft lbs.
5. 1/2" bolts 75 ft lbs.
Have nice day.
Jul 08, 2012 | 1979 Harley Davidson XLH 1000 Sportster
Im having problems starting my 1976 Harley Davidson sportster
check the simple things first 1 coil 2 condenser 3 points 4 gas compression I need more info for any real help
Apr 23, 2012 | 1979 Harley Davidson XLH 1000 Sportster
Harley davidson xlh 1000
Hi Dawne, for more information about your question please visit the website below. Good luck and have nice day.
Mar 15, 2012 | 1979 Harley Davidson XLH 1000 Sportster
I have a 1979 harley davidson ironhead sportster 1000 cc . I have had 3 condensors, 2 sets of points installed this riding season. What might be causing this issue ?
The '79 model came with electronic ignition and someone has converted it back to a points type ignition system. I'm betting that they did not change the coil. Check the resistance of the primary of the coil. It should be between 5-6 Ohms of resistance for use with points. A coil designed for use with an electronic igntion uses a coild with 2-3 ohms of resistance in the primary winding.
good luck
Steve
Aug 01, 2011 | 1979 Harley Davidson XLH 1000 Sportster
1982 harley davidson sportster XLH . Lost compression while riding . and it died. have electric but will not turn over or start. pistons not moving. gears work but there is not much resistance. . where do...
You need to tear the motor down, sounds as if the pistons seized or you broke a connecting rod, or bearings went out.
In any case you need to have someone that knows what they are doing check it out for you.
Nov 08, 2009 | 1979 Harley Davidson XLH 1000 Sportster
1985 harley 1000 no compression in front head
remove the push rod tubee on the front jug.see if the pushrods are moving up and down.see if they are loose.if loose adjust try again.
your valves may be stuck open if not stuck open pour 1 once of mystery oil in head try comp test again.[this is to check the rings}if still no comp you have a hole in your piston or blown head gasket
Jun 20, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
