Question about Sportcraft Tx350 Treadmill Motor Speed Controller Board Fh-3511c Circuit Control
Need to order a control board
How can I order one
  • 3,904 Answers
I am not sure they carry these boards but most certainly worth a call is Allied Electronics. If they don't have one I know they will steer you the right direction.
Posted on May 14, 2014
My ge profile refrigerator temperature digital printout reads 999,888,777, etc. Is this a main control panel problem, thermostat or digital control itself?
This is just a bad display control board. You need to replace the actual display control board in order to correct the issue unfortunately. I'm not sure what shorted out both your main control and your display control board, but you will need to replace your display control now. hope this helps :)
Aug 04, 2013 | Refrigerators
No lights on control board, door locked, MAH9700
Unfortunately the control board is dead and will need to be replaced. Here is the board to order if you decide to order it.
The E2 error code was for a stuck button and it would require the control board to be replaced also.
Dec 08, 2012 | Maytag MAH9700AWM Neptune Front Load...
My dometic model #2652 has no electric,why??
Check the fuses on the lower back of the unit. There is a control board with them on it. If the fuses are good, you will need to replace the control board. Here is the manual for that unit.
Here is the control board in case you need to order it.
Nov 09, 2012 | Dometic RM2652 Refrigerator
Code F- Won't spin
Hi, it means you have an internal short in the display control board. You'll need to order and replace the relay control board in order to correct the issue. This control board is located on the far right corner under the control panel. Below is a link to the control board you'll need to order and replace. Click HERE.....
Mar 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Vision Fitness t8500 treadmill's deck just stopped working. It makes no noise when i turn it on. all other functions (elevations & programs) work fine. any troubleshooting ideas?
I had the same problem. I even ordered a $300 controller board. The new board didn't work either. That's when I started checking voltages from the control board to the motor. That was good. Lastly I checked the brushes. Almost nothing left. . . The motor started working again after I put everything back together. I need to order new brushes and return that contoller board.
Dec 28, 2009 | Exercise & Fitness
Power will not come on to control panel. Door light comes on and the locked light comes on
Check and make sure you have proper voltage at the plug, reset yoru breaker.
Also are the led indicators dim (lights) on the interface board. Watch your terminology as there is a control board but it has no lights on it. Id hate to see you order a control board when you need an interface board. Well if the leds are dim then remove top and reseat all ribbon cables 4 each on the interface board and the control board. then turn it back on and see if it works. If not replace interface board then the control board in that order.
Oct 27, 2009 | Whirlpool GEW9250 Electric Dryer
I have a kenmoore oven model 91140465690 that keeps beeping and flashing the code F7 i need to know what part i need to replace for that code
HI, this F-7 code represents one or more function keys on the control board that are malfunctioning or stuck.
This will require the replacement of the entire control board(ERC,Clock).
Replacing the ERC(Electronic Range Control), will fix this issue. this control board will run you about $140.00 tops. you can order it on line by clicking the link i have provided below this text if you choose.
Click here to order you new replacement ERC.
Jun 17, 2009 | Kenmore Ovens
Seagate freeagent 500gb desktop hd
cannot get my freegate to backup to my hard drive
Oct 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Sportcraft Tx350 Treadmill Motor Speed Controller Board Fh-3511c Circuit Control Logo
93 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
