Question about Danze & Single Handle Tub And Shower Faucet
How do you remove a shower valve handle and trim plate?
How do you remove the shower valve trim and handle of a Danze Fairmont shower valve?
  • 14 Answers
SOURCE: water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Posted on Jan 03, 2009
  • 92 Answers
SOURCE: Cannot get the cap off the shower handle of a Danze fixture
not familiar with that exact unit but alot of the caps unscrew or pop out when pried or you may have set screw on body
Posted on Feb 23, 2009
  • 2976 Answers
SOURCE: Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Posted on Apr 06, 2009
Bati99
  • 88 Answers
SOURCE: Shower valve leaking
here is the link to the pdf file http://www.plumbersurplus.com/pdf/07606.pdf
If you cant get directly to it from the above link, go to plumbersurplus.com/prod/danze-D51001BNT then click on "documents"
Posted on Apr 17, 2009
  • 18 Answers
SOURCE: Danze shower kit
SORRY, ITS SO.... BUT GOOD FOR YOU THIS ISN'T MY FIRST RODEO... TELL YOUR HUSBAND TO ADD THIS TO HIS NEVER ENDING TO-DO LIST: YOU CAN ADD A SHOWER HEAD VALVE WHICH DEPENDING ON YOUR FINISH ONLY COSTS ABOUT 15 DOLLARS AND TAKES 2 MINUTES TO INSTALL. I ACTUALLY HAVE ONE ON MY DANZE VENETIAN BRONZE TUB AND SHOWER FAUCET FOR THE EXACT SAME REASON. YOU SIMPLY REMOVE THE SHOWER HEAD, THEN ADD THE VALVE, THEN ATTACH THE SHOWER HEAD TO THE VALVE. ADJUST FOR THE DESIRED PRESSURE. SORRY HUBBIE
Posted on Dec 29, 2009
The Fairmont has no apparent way to remove the handle to permit replacement of the cartriodge. How?
they either have a small cap on front to pop off then screw under cap..or they have under or to side of handle a very tiny set screw recessed...it is a allen screw...loosen and pull out...
Mar 12, 2011 | Danze Sheridan Tub & Shower Faucet
I have water coming up through the centre,under handle,only when turned on
Hi
This sounds like there is dirt under the cartridge you would need to turn the water off and take the cartridge out and clean the valve as well. this should stop the water coming through
Mar 14, 2010 | Danze D500540BNT Brushed Nickel Fairmont??...
I need an adapter for a roman tub filler the aerator is about an inch and one sixteenth round with fine threads i would like to install a diverter for a handshower thanks
c51b8b5.jpgPersonal Shower Adapter Fitting
Remove the aerator from the spout and take it with you to your local hardware store or home center (for sizing purposes). These are usually sold with an aerator thread adapter, which allows it to connect to most faucets in the marketplace.
Feb 06, 2010 | Danze Fairmont Double Handle Roman Tub...
How do you fix a dripping shower faucet? It is not leaking from the hot or cold handles, but the spout itself.
if it is an old fashioned valve then there are cone washers in the valves that control on and off
they are fairly easy and cheap to replace
Jan 11, 2010 | Danze D316440RBT Fairmont Two Handle Wall...
Danze D500540BNT Brushed Nickel single handle leaks
only when its on? it can only be from 3 places the the plumbing up to shower head or the tub spout or crack in fixture make a hole in the wall behind fixture easier then replaceing tile if you can turn on and see where the water is coming from you need to open anyways thank you for useing fixya please rate me
Feb 23, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
Danze shower fixture issue
If it is a single handle there should be an access hole to the under side of the handle that will allow access to a allen style set screw, loosen it and the handle can be removed.
Feb 21, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
How to you get the cap off the shower handle/
try a magnet before drilling if it don't work drill a small hole do not push in to screw
Water leaking from tap when turned off
Hope this helps.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Danze & Single Handle Tub And Shower Faucet  Logo
101 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Mike Herrington
Mike Herrington
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
