Question about Garden
How can I fix a loose wheel on craftsman 675 rear drive mower?
I can see some kind of a bearing that looks like it holds the wheel close to the body of the mower. It looks like the inner flange broke off. I can't see in the manual what that part is called. I can replace it myself, I think, but I don't know part number.
  • 92 Answers
Don't know part # but I'd take to dealer and see exactly what it is and look online for cheaper part cause yer gonna pay top $ at dealer
Posted on May 14, 2014
SOURCE: A part on my Scotts 16 '' Elite push mower broke
The number Jakeyjones gave is the customer service number. Call it and describe your problem.
As for the gear, I had the same issue. I called customer service and was told that there was a supplier material issue that caused some gears made last year to break more easily than they are supposed to. They are sending me 2 new pinion gears completely free of charge. These are the black plastic gears that engage against the orange wheels to make the blades spin. Make sure you don't lose the pawls (metal rectangular pins that go through the shaft to engage the pinion gears).
1-800-618-7474
I called at noon eastern time today. The woman I spoke with was very helpful and knew exactly what parts to give me.
Posted on May 19, 2009
  • 59 Answers
SOURCE: Have honda harmony 11 HR 216 that stopped being
it has a belt look under the mower
Posted on Jun 26, 2009
  • 10865 Answers
SOURCE: craftsman 675 series manual
go to sears direct. Enter your model number and download your manual. Joe
Posted on May 23, 2010
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Posted on Jul 02, 2010
rycgl
  • 1545 Answers
SOURCE: where is the carburetor on
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Posted on Apr 13, 2011
I have a craftsman 675 electric start front wheel drive.
Take the wheel off the axle. Should be one nut 9/16?. Remove the C-clip that holds the gear--remove gear. Reverse for install.
Apr 16, 2016 | Craftsman Garden
How to remove drive wheels
Although I'm not familiar with this model, on some, you remove the center hub cap, and remove the bolt underneath. The wheel should slide right off.
Jun 23, 2015 | Craftsman 675 Series 190cc 22" Briggs ...
Front wheels lock up when mower pulled backwards
Not uncommon for the drive to turn in only one direction.
Why is mower making sound like blade hitting deck?
when does it do it ??? Only when you are driving the mower ??? if its a rear drive mower I would suspect the axle/trans/drive wheels are making the noise.
Sep 11, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
My 2003 FORD TAURUS IS VIBRATING WHEN I ACCELERATE MORE THAN 60 MPH. IVE REPLACED MY TIRES WITH NEW ONES AND THEY WERE ALSO BALANCED. ONCE I TAKE MY FOOT OFF THE ACCELERATION THE VIBRATION STOPS.
The trans axle in the transmission has too much play from wear. It works like a rear end in a rear wheel drive.Excessive wear there will give you that kind of vibration.It could be wore out.
Oct 28, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
675 series self-propelled - Front right wheel bearing assembly separated, wheel wobbles
I would take it back to the store and ask for warranty repairs since it is so new. That's ridiculous. If that doesn't work, try Sears Parts on-line or on the phone. They are better than most other manufactures.
Oct 12, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
I have a 675 190cc push lawn mower. How do I( remove the plastic housing to tighten the rear wheels?
There are a few versions of the 675. Can you find the actual model number? It would be something like 37223. Then I can look up a parts diagram and be of more help. If they are wheel covers they just pop off with a small slotted screwdriver.
Aug 25, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman 6.5,22 inch cut. model# 917.379470
does not sound good the off balance of a loose blade could have caused the rod to break inside the engine the age of mower and how much use it has had could be a factor only way to really know it to look inside the crankcase.
Jun 06, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
The front drive self propelled wheels stick and squeal
why is the back wheels of my briggs stratton wont stop turning
Aug 29, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I Have a Craftsman 675 Series When I try to start the mower it will not keep running unless I keep pumping the primer button and then it will start are there any kind of carburater adjustments. What can I...
There is one thing fairly easy you can try. You take the aluminum bowl (bottom) off the carburetor. There will be a brass bolt with a washer holding it on. When you do this the carb will leak gas so you should drain the fuel first or stick something under the carb to collect it. There will also be a gasket between the bowl and carb body. Don't mess it up. The bowl should be cleaned and have no residue or dirt or water in it..the brass bolt is the big concern here though. Inspect it closely ...tiny holes in the smooth part above the threads...and bottom...make sure they are clear. Use carb cleaner Dont enlarge any of the holes...clean with toothpicks, no metal....this is the main jet to the carb. Try it.
Jun 07, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
