Question about Ericsson Cell Phones
How to establish a connection with a phone number that does not seem to be working
When i call the phone the phone rings but the person cannot hear me, however it only happens to that specific number
This happens occasionally to me. Hanging up and trying again helps. If that doesn't work, have them call you, or you call from a different phone. If that doesn't work, think about whether you or they have reception where you both are. Hope that helps
Posted on May 14, 2014
  • 316 Answers
SOURCE: cannot hear when call received
try answer the call and then raise the volume if this does not work return it
Posted on Nov 26, 2007
SOURCE: Motorola RazR V3 not working while charging
i am having that same problem........my razor had a fall and when i picked it up back there was no sound also it wasnt able to charge however i opened it and i realized that the speaker moved a little so i put it back where it suppose to be........after i powered up the fone the sound was back but styll not charging..nor recongnized by the pc....
Posted on Jan 27, 2008
kaaaar
  • 22 Answers
SOURCE: cannot hear ringing tone or voices
Its the problem with the speaker... Change it...
Posted on Dec 27, 2008
mail2pvs
  • 390 Answers
SOURCE: when making calls, can not hear ring or person
connect your head set to check if you have the voice on the headset
if yes then you may have to get the phone ear speaker changed
cheers
pls rate the solution
Posted on Jun 29, 2009
SOURCE: Problem with Nokia 6300 - Can't hear anything
You need to changed,Your mouth piece, and you earpiece.
As for your ringer, it can be changed,but sometimes the problems always from the panel of the phone,and when it's from there, and ones is from there,it's damaged.
For your mouth piece and your earpiece it will workafter changing it.
Posted on Jan 20, 2010
I can phone a number and they can hear me but I don't hear it ringing at the other end or hear the person I have rung, any help please?
If you can fixed it, fixed it by yourself by replacing a new speaker.
If not please refer to the nearest mobile service to solve your problem.
Thanks for using FixYa!
Sep 27, 2012 | Sony Ericsson Cyber-shot C902 Cellular...
Can't hear the person calling me but they can hear me. Everything else seems to be working ok.
Have you tried using a blue tooth or a hands free set,also try your speaker phone,Once you have established what area the problem resides in ,i can help you.
May 13, 2010 | Motorola Mobility RAZR V3
My fax machine starts before a answer phone starts When somebody telephones me and I am unavailable instead of being able to leave a message on my answer phone the call er hears the fax connecting
I established that my telephone answering system started after 6 rings, by reducing this to only four rings the answering system operated prior to the fax tone kicked in - now it all works fine
Nov 13, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Phone numbers
Try changing the advanced fax setting rings to the same style of rings as distinctive ring-All, two shorts, two longs etc.
Apr 29, 2009 | Vtech 5.8GHz Analog Cordless Phone
My house phone rings when someone calls but we can't hear it ring nor can we get a dial tone to call out
The ringing you hear when you dial your phone number is not actually your phone ringing but a machine at the phone company designed to give you something to listen to while they connect your call. I would say that your phone number is working, just not at your house. You need to call repair to trace your phone line and get it connected properly. Good luck
Jul 17, 2008 | Lands Phones
Can't answer phone
Either the connectivity in your area is poor or the your network could be conjested in your area with more than the max no. of users.
Dec 01, 2007 | Samsung SGH-D500 Cellular Phone
Cell Phones Logo
19 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
isaac johny
isaac johny
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
