Question about Porter Cable Tools & Hardware - Others
Porter Cable Plane totally dead after working a minute
I have a Porter cable 653 Versa Plane with probably less than an hour's use on it. Bought 20 years ago and kept in case. Needed it for smoothing a joist, worked for only one minute and quit working. Won't restart. Checked power with a voltmeter, getting 120V. Tried another outlet, same thing, plane is totally dead. Should I try working on this. Seems built very well with removable covers. First I could check switch with ohmmeter but doubt that's the problem. Any help appreciated.
Thanks
  • 3 more comments
  • sdooley350 Jun 24, 2009
    I took the cover off the on off switch on the plane (porter Cable 653 versa plane) and it was very clean (used no more than 1 hour). I used a Fluke ohmeter and checked the switch. It had continuity on both the hot and neutral (both switched w 2 pole switch) when trigger pushed and no continuity when released. There was a screw in brush holder which had a spring loaded brush which looked fine. I reinserted brush and put the plane back together and it still wouldn't work. I guess next I need to look at the motor connections. Any ideas?
  • sdooley350 Jun 25, 2009
    I should have checked the second brush. I notice one of the brushes is stuck and won/t come out rather than moving freely up and down with the spring. I'm sure this is the problem but don't know how to force the brush back. Not sure if this is because the planer sat in the attic in its case for several years before being moved inside. Didn't operate it for 22 years.
    Thanks for any ideas.
    Sorry to keep adding more info but the brush that is stuck is stuck in the brush holder which looks to be made of brass. Rather than risk breaking the brush I sprayed w WD40 for now. Hope to get it loose but may have to order a new brush. Then I hope replacing the brush fixes the problem rather than being from some other cause. The planer was working, sat in case (sometimes in hot attic) for 22 years, then ran for one minute before quitting.
  • sdooley350 Jun 26, 2009
    I took a needle nose pliers and tried to pull the brush out using the wire but the wire broke loose from the brush leaving the outer portion of the brush still lodged in the brass brush holder and the rest of the brush being pulled out leaving a hole. Using a screwdriver I removed half of the brush still lodged. Next I'll take an allen wrench and remove the brush holder which I probably should have done 1st last time. In the meantime I called a porter cable service center where they informed me brushes were no longer available for my model. They suggested either a motor repair shop or bringing the good brush to them to try finding something similar. Unfortunately they are 80 miles from here but don't know what else to try. I Appreciate your help so far. Guess that's the way to get you to buy the newer model.
  • sdooley350 Jun 29, 2009
    Thanks ProHydroRace for the suggestion to try hardware stores. Ace hardware had a nice selection. Didn'tcheck NAPA but they might have had bushes too. Picked one with dimensions same on brush except for length. Since tension was greater and wire 3/4" longer, desoldered their wire from round contact, cut wire, inserted wire in hole from old contact after shortening, used dremel to cut off 1/4 of new brush length. Ended up with something virtually the same as the old brush. Put together and ... IT WORKS.
    Thanks for your help. Would have been hard to replace with another planer with as short a time I used the planer.
    Sergeant:
  • 384 Answers
The power switch may be dirty. Try blow it out with air and or solvent.
Posted on Jun 23, 2009
  • 1 more comment
  • ProHydroRace Jun 25, 2009
    The brush is made of carbon and the holder is brass. The two different material should not stick together. The brush may have broken jamming a piece between the holder and brush. Check that the wire going to the brush is still attached. Can you use a needle point pliers to remove brush? If not you may have to disassemble the whole motor to get to the brush. I have done it on an electric B&D edger...it is a pain to get to.
  • ProHydroRace Jun 26, 2009
    Hold on a minute. At many oy your local hardware stores (the older store the better) talk with the guy in the back of the store. Many times they will have a selection of motor brushes. If that doesn't work I would search the net for replacements. Good luck.
  • ProHydroRace Jun 29, 2009
    I love those ACE Hardware stores. Prices are on the higher side BUT they seem to have what you need. I raced boats for years and I called ACE my place for Racing Gear...from glues, epoxies, paint, and hardware.
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
Rebuild porter cable framing nailer
This model suffers from cylinder seal failure (large plastic seal sitting on top of cylinder) and sticking headvalve. Easy to fix however. Remove head and pop out the headvalve . Lube the headvalve orings with white grease and reinstall. Replace the plastic cylinder seal with Ridgid seal #079020001013, same part as porter cable but cost less. Good luck
Jan 09, 2014 | Porter Cable Cable No. FR350A Rnd Head...
While driving, successive loss of power culminating in the engine dying. Lights still working but engine would not start. After 5 minutes everyhing dead. 1 hour later engine starts and works for less...
Sounds like it could possibly be a bad alternator if all the cables are tight and started out with a good battery. Do you have a battery or red charge light? Or, alternatively, is there an absence of this light when the car ignition is on, but the car has not yet been started?
Good luck on this repair.
Dec 18, 2010 | 1991 Toyota Corolla
I have a Porter Cable door planer with carbide tip blade and it has a small notch from a conceiled finish nail on an old door.The blade is still good.I would like to know how I can sharpen it.
Hi, these blades are made to fine tolerances, so I would not attempt to sharpen it. But they are also double sided. Just undo with the appropriate allen wrench and flip it over. Good luck!
Nov 15, 2010 | Porter Cable 9118 #126 Porta Plane Door...
How do I adjust the depth of the brad nail on the porter cable BN 125A brad nailer
Hello. To adjust the depth of the nail you have to increase or decrease the air pressure from the compressor. Look at the compressor and you will see a knob or dial that you can turn to increase or decrease the air pressure. Do this adjustment in small increments testing the nailer by driving nails into a scrap of the same material you will be driving the nails into on the actual job. Increasing the pressure will drive the nail deeper and decreasing the pressure will drive the nail less deep. Joe
Nov 10, 2010 | Porter Cable Cable BN125A Factory -...
Bought new porter cable oiless boss compressor and want to know what i need to do before operatining it for intial use
The first thing is to make sure the compressor pump has oil!
Run the unit with the tank drain open for 10 minutes to break the compressor and rings in. Let the motor cool for 30 minutes and then use the compressor as normal.
Make sure to change the oil every 50 hours of use
Sep 26, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
18v nicad charger blinks short on battery on both batteries
Probably both batteries are dead. Unusual for both to go at the same time but that sounds like the problem.
Aug 07, 2010 | Porter Cable-Cable PCL180DK-2 18-Volt...
Need a new planer blade 43233
after 5 hours searching on Google and Yahoo I settled for blade 43263 which was a lot more expensive
Nov 28, 2009 | Porter Cable 9118 #126 Porta Plane Door...
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Tools & Hardware - Others Logo
334 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
