Question about AEG Lavamat 72640 Front Load Washer
E10 the machine would show E10 then I could press start to continue cycle. However then on the last cycle that was used it continued to fill with water, overflowing and flooding the laundry.
4 Suggested Answers
  • 1462 Answers
SOURCE: Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Posted on Apr 10, 2007
SOURCE: e10 ERROR COMING UP, HAVE CHECKED THE HOSES AT THE
Did you check the little filters in the end of the valves where the hose connects to the machine, also if these are original Electrolux hoses you will find that at the other end of the hose where they connect to the mains pipe there are fine wire mesh filters in the ends of the nylon connections.You may well have water flow but the pressure is not good enough, especially during the rinse cycles.If none of these fix the problem then you may have a faulty inlet valve.Wish you well.
regards.
Posted on Jun 29, 2010
mfiermonte
  • 10 Answers
SOURCE: washing machine not filling
Check the screens at the point where your water hoses connect to the washer. These often get clogged with calcium. A simple vinegar soak or cleaning with a brush will often solve this problem
1. Turn off the water supply at the valve
2 Place a towel or bucket behind the washing machine to catch remaining water coming from the removed hose
3. See if the screen (often cone shaped) is inside the washer side or the hose itself.
Remove the screen, clean it, and replace.
I hope this works.
Posted on Mar 08, 2014
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
EWX14450 washer dryer. Drain works fine. Why is it overflowing?
Found the problem with mine that had identical symptoms... after taking the lid off. i took the pressure switch off the hose. blew on the pressure switch when filling and you can hear the 3 clicks. the machine resumed onto next phase. i blew down the hose and this was clear and bubbling into machine. but then i discovered half way down the hose - it was damaged and had a hole. presumably from the drum rubbing on the hose over many years. now just need too replace this and it should work fine.
Apr 29, 2013 | Electrolux Washing Machines
My fridgedaire affinity washing machine washes the clothes, then drains then starts to do a light tumble right and left. it never goes into a rinse cycle. It finally stops and shows an error code E10. I...
it could be that your rinse water valve has gone turn off all power and take the top off you can see the water valves at the back of the machine if you have a multi meter you can test the valves for continuity if ok then your filter might be blocked try the filter first
Oct 16, 2011 | Frigidaire Affinity ATF7000E Front Load...
Electrolux ewf1083 stops mid cycle displays e10 .press start button and continues but can happen up to 4 times per wash.any ideas?
We had the E10 error on EWF1083, I opened the top cover and looked into it. It's the 2 way solenoid valve and should be a easy replacement. Looked on ebay and $59 for the part ex postage
Oct 12, 2011 | Washing Machines
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
Water continues to fill
well, i'll tell you. take it back. i overheard a repairman say they are sorry machines. i wanted to buy one until i heard that last summer.
Jan 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
AEG Lavamat 72640 Front Load Washer Logo
22 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
