Question about Bosch Refrigerators
Why is my Bosch B22CS80SNS/01 display not working
Display panel is not working at all. No temp control, no dispensing water or ice. It doesn't say "Sabbath" on the display.
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Bosch B22CS80SNS sxs with no lights
You can get the manual here. on page 16 it tells you how to take off savagemode.
Sabbatical mode settings:
– Accoustic signal is switched off.
– Super cool or Super freezing
functions are ended (if activated).
– The interior illumination is
switched off.
– The light on the display panel is
reduced to basic lighting.
– Buttons are locked (except
“options” and “+” buttons).
Switching on and off:
̨ Simultaneously press “options”
and “+” buttons for 5 seconds
When switched on, [Sabbath] is
indicated on the display panel.
Good Luck
Posted on Nov 02, 2009
No ice or water dispensing
More than likely you need to change your filter or you may have a bad water valve. Good Luck!
Jul 24, 2015 | Bosch B22CS80SNS (220 cu ft) Side by Side...
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
The control panal on freezer door says 56-56 will not despence water or ice
Good Afternoon Friend,
I understand that you are receiving a 56 56 code on the display of your Frigidaire refrigerator, model# GLHS269ZDB. I also see that it is not dispensing ice or water, even though you have reset it by unplugging it. The 56 56 is actually SB SB. This tells me that your refrigerator is in Sabbath mode. To exit the Sabbath mode, press and hold the down arrow and the plus sign, simultaneously for 5-10 seconds or until the display changes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
The digital read out shows 56 will not reset will not despense water or ice
I understand that you are receiving a 56 code on the display of your Frigidaire refrigerator, model# FRS26H5AS. I also see that it is not dispensing ice or water, even though you have reset it by unplugging it. The 56 is actually SB. This tells me that your refrigerator is in Sabbath mode. To exit the Sabbath mode, press and hold the down arrow and the plus sign, simultaneously for 5-10 seconds or until the display changes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire FRS26H5AS Side by Side...
Control panel is locked up and displaying the numbers 56 56. Both compartment lights are out, water and ice not dispensing. Could it just be a door switch?
I understand that your Frigidaire refrigerator, is having trouble with the ice dispenser, control panel, and both interior lights went out. I also see that the numbers 56 56 are displayed on your panel. If the numbers are showing Sb, this tells me it is in the Sabbath mode. To get out of this mode you will need to press and hold the down arrow on the freezer side and the up arrow on the refrigerator side simultaneously for 5-10 seconds. If this does not work, I suggest resetting your appliance. You can do this by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and check the control panel as well as the ice dispenser and lights. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Refrigerators
Inside lights of KitchenAid KSF26C4XYY not illuminate
I bet your fridge was put into Sabbath Mode.
Sabbath Mode is designed for those whose religious observances
require turning off the lights and dispensers.
In Sabbath Mode, the temperature set points remain unchanged,
but the interior and dispenser lights turn off, all sounds and alarms
are disabled, the dispenser display screen backlight turns off, and
the dispenser levers are disabled
To turn on Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds. When the feature
turns on, "Sabbath Mode" will appear on the dispenser
display.
To turn off Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds again.
Apr 15, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Despenser light no longer works.
if you mean light for water and ice dispenser they upgraded to a new led ring mine went out to you can get part from bosch parts website
Dec 08, 2013 | Bosch B22CS80SNS (220 cu ft) Side by Side...
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
GE Profile refrigerator pss26sgrcss isn't dispensing water, and 2 days control panel isn't working either. Not running and not cold at all, what are possible problems and solutions?
check for power at the display if power is present then you need a new interface (display) if no power is there then you need a new mother board located on the back of the unit square panel..mother board part#- WR55X10942--interface (display)-part#WR55X10390
Mar 27, 2012 | Refrigerators
I just bought a Bosch Linea B22CS80SNS. Where is the serial number located? Thanks much
The serial number is located on the inside of the refrigerator section, on the right side of the first vegetable bin on the panel.
Aug 29, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Refrigerators Logo
119 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
