Question about Dishwashers
Why is the bottom drawer stuck?
The bottom drawer of this machine is jammed in such a way it will either not open unless forced and if open will not close unless really forced. Is this common and is there a common solution?
    Scholar:
    New Friend:
  • 77 Answers
Is this a Fisher Paykel Dishdrawer?
If so, the lid is likely not returning properly to the upmost position.
Caused by faulty lid actuators, easily fixed by replacing them.
Try not to open and close forcefully as it will damage the rubber seal (built into the lid), then you will also have to replace the lid.
Posted on May 28, 2014
  • 145 Answers
SOURCE: fisher & paykel top drawer stuck again
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
Posted on May 15, 2008
SOURCE: bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Posted on Nov 25, 2008
SOURCE: Fisher and Paykel DD603 top drawer jammed and will
Hey, I had this problem before!!!! Just unplug the unit off and wait about 10sec and plug it back on.....that usually does the trick.
Posted on Nov 26, 2009
  • 713 Answers
SOURCE: dishwasher lid stuck
the lids on dishdrawers are pulled down and sealed by lid activaters. there r two types, the screw type and the magnetic solonoid type. the reason your draw gets stuck is your lid activator is not releasing. there are 2 reasons for this 1st- 1 or both activators are faulty. 2nd the lid activator control board is faulty, which is located under the bottom drawer.pull the draw out and see if u can see if the lid is down on 1 side or both sides.please reply 4 more help.
Posted on May 04, 2010
Testimonial: "Thanks Luisa! We replaced the lid activator 2 years ago - it cost us $250. The problem has occurred twice since. We were able to trigger the lid to open by unplugging the dishwasher and plugging it back in. Symptom is cured, problem is not. How hard is it to replace lid activator?"
  • 3247 Answers
SOURCE: fisher paykel heater plate replacement
The problem is the thermal fuse in the bottom drawer which shuts of the controller power. But the thermal fuse is part of the heater assembly. So you will have to replace the lot.
It is not an easy procedure to replace the heater assembly as the whole system is intervined with the pump and motor components.
You will have to disconnect all wiring and hoses from the base of the drawer once you have it out after removing the transparent plastic wiring cover.
Then you have to release the locking ring to remove the pump and motor assembly along with the heater plate.
Hope this helps. please rate the solution if ok otherwise drop a comment.
Posted on Aug 16, 2010
The dispenser drawer on my AEG Lavamat is stuck half open and appears jammed. Help please
Open the machine up on the top lid. 2 screws at the back of the machine at the top. Slide the lid back and remove it. The drawer can now be accessed. There should be a bunch of clips holding the lid of the drawer . You can carefully open these clips to remove the lid or just remove the entire drawer assembly and replace it or try to figure out what is jamming it.
Jan 22, 2018 | AEG Washing Machines
The freezer drawer is stuck won't open?
Defrost to open - ice jammed up inside. Force it, you break it.
Jul 22, 2017 | Refrigerators
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
Oven drawer stuck
It's stuck on the runner,only way is to use a wood pry tool to force it open
Aug 18, 2014 | Smeg Cooktops
How to open a stuck CD drawer in Marantz UD7006?
You will have to remove the outside cover to expose internal parts, then you may be able to "help" the drawer open unless something is jamming it or broken.
Jul 23, 2014 | Marantz UD8004 Universal Disc Player...
Drawer wont slide and dishwasher does not work
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Dec 07, 2012 | Fisher and Paykel Dishwashers
Jammed soap drawer
hiya
yes the screws are behind the soap drawer, will the drawer not open at all? if not then the only way would be to force it open and the chances are it will break and need replacing. if it opens about 2/3's of the way try pressing the thin blue locking tab in the middle of the two channels and pulling.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Jul 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
