Question about Zebra 110Xi III Plus Thermal Printer
Labels covered in "Void"
Prints several labels correctly, then starts printing labels covered with the word "void"
    Scholar:
  • 122 Answers
This is coming from your label software. It commonly does this when a trial period has expired or the license you have has been corrupted. Please contact the manufacturer of the label software that you are using for support.
Posted on Jun 23, 2009
  • 32 Answers
It is not a license issue. Has the software changed? Have the printer settings changed? This is where your culprit lies. I have 10 years experience as an employee at Zebra, the last 5 being on the RFID team. Let's look at these two things first.
Posted on Oct 27, 2009
  • Jodi Minshall
    Jodi Minshall May 19, 2015
    This is a new printer and it started doing this as soon as we put new labels and ribbon in the printer. Any other ideas?
IF your are print RFID labels, then means the RFID encoding error out. The label is most likely bad. You can modifed the error handling using the ^RS command.
Posted on Jul 22, 2009
Datamax I-Class I-4208 void
If the word "VOID" prints, turn the printer off, reboot your computer, turn the printer back on, and try printing again.
Oct 23, 2011 | Datamax I-4208 Thermal Label Printer
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
How do I feed an AVERY label 5453 into the printer?
Just place the sheet of labels in the paper tray.
You may need to place the labels face down in the paper tray so the prints on the correct side of the labels. If it didn't print on the correct side of the labels then place the labels face up.
Jan 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Zebra printer 2844: prints one label and spits out several empty labels and stops midpoint of a label. To print again, I must correct the label position, turn off then on. Cannot get dump to...
If you are using a windows system please go into the control panel by clicking the start button and choosing control panel. In the control panel go into the printers, right click on the label printer,choose printer properties and then click the tab labeled printing preferences. Choose the page setup tab and please let me know the size that is specified next to the name.
-Kyle
Sep 16, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
When I print my labels, there are lines that run through it
The lines(voids) are being caused by elements that are worn off the printhead. No energy is getting there to release the ribbon, causing a void area. To see the full extent, just create a label, using your widest label, that prints a thick black line. You will easily see the "void" areas as white lines.
This is common over time due to the constant contact with the ribbon. The elements wear down just like the tires on a car from the constant contact with the road.
The only way to correct is to install a new printhead.
Apr 28, 2010 | Zebra Z4Mplus Label Printer
Label over run
Check the size of the label in your codes or driver.
The length must be correct or else you cannot use it correctly.
You must may be recallibrate the sensors
May 17, 2009 | Toshiba TEC B-452 Thermal Label Printer
Polyester labels from tray 1 4 labels per sheet right side color
It says on the website the labels are 56lb (I guess cover weight). The only way the stock will run right (ie) fuse correctly is in the mp tray using one of the thicker settings. Also if you run labels out of the tray you run the risk of them peeling off making the turn out of the tray and into the machine. All non standard paper is better off using the mp tray.
Mar 29, 2009 | OKI C5150n Led Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Zebra 110Xi III Plus Thermal Printer Logo
204 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
