Question about Home
How can I get ONE copy of The Headmaster's Wife" ?
Each time I try to order, the order says I have 4-5 books in my cart.
Is it true that his first wife said Donald Trump kept a copy of Mein Kampf by his bedside and said its author was a great leader?
Trump then recalled, "Actually, it was my friend Marty Davis from Paramount who gave me a copy of 'Mein Kampf,' and he's a Jew."
Brenner added that Davis did acknowledge that he gave Trump a book about Hit**r.
"But it was 'My New Order,' Hit ***'s speeches, not 'Mein Kampf,'" Davis reportedly said. "I thought he would find it interesting. I am his friend, but I'm not Jewish."
Donald Trump's ex-wife once said Trump kept a ... - Business Insider
www.businessinsider.com/donald-trumps-ex-wife-once-said-he-kept-a-book-of-hitrs...
  1. Cached
  2. Similar
Sep 1, 2015 - Donald Trump's ex-wife once said Trump kept a book of Hits speeches by his bed ... Michael Kennedy that her husband, real-estate mogul Donald Trump, now a ... speeches, My New Order, which he keeps in a cabinet by his bed . ... from Paramount who gave me a copy of 'Mein Kampf,' and he's a Jew.
Vanity Fair: Trump Kept a Volume of Hit's Speeches By His Bedside ...
www.weeklystandard.com/vanity-fair-trump-kept-a...of...his-bedside/.../2001343
  1. Cached
Mar 1, 2016 - Of all the crazy revelations about Donald Trump, arguably the one that seems most alarming, is that he has a fondness for reading Hit speeches. ... Last April, perhaps in a surge of Czech nationalism, Ivana Trump told her lawyer Michael Kennedy that from time to time her husband ...
Donald Trump kept a book of Hit's speeches by his bed, according ...
www.independent.co.uk > News > World > Americas
  1. Cached
  2. Similar
Dec 8, 2015 - Donald Trump kept a book of Hit's speeches by his bed, according ... from Paramount who gave me a copy of 'Mein Kampf,' and he's a Jew.". Is it true that his first wife said Donald Trump kept copy of Mein Kampf...
Dec 05, 2016 | Cars & Trucks
You are sending books to my kindle fire that my wife orders for her kindle but she is paying for books she is not getting
Sounds like your wife's kindle is registered in your name. You can find out by logging into your account on amazon. Up the top open your account window then scroll down and click on " Manage Your Devices". If your wife's kindle in on your account then you have to unregistered it from your account then see would register it in her name. She can do this while on her kindle table.
Feb 23, 2015 | Amazon Kindle Fire HD
Cancel order for book
Check the website you used to order the book. There should be an option to cancel your order either in shopping history or your shopping cart.
Cheers,
Tom
Aug 28, 2014 | Computers & Internet
Going through toner too fast. Changed toner two days ago. Asking to be replaced and have to shake toner. Yes, we are sure it was a new one :-)
TN -430 toner cart. 2500 copy count.
TN -460 toner cart. 4000 copy count
These are the two units that fit the 4100 modles .
You must be receving all lot faxs to use up the toner that fast.
You can go in to setup and change the toner to use less. Will need service book that came with the unit. Hope this helps
Aug 12, 2010 | Brother IntelliFax-4100e Fax
Dell Photo 926 printer keeps saying that it cant align and wont print after installing new cartridges. Says tape is still on there but it isnt.
1. cancel the alignment .
2. try one cart at a time and only make a copy of a test document ...(press "select" if u get cart missing error ) ...only of the carts is causing the error
3. possible u have defect cart ..or the internal sensor could have gone bad (rare scenario )
4. get a replacement carts...
Oct 25, 2009 | Dell 962 Photo All-In-One InkJet Printer
The add toner light stays on with a new toner cartridge
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Jan 06, 2009 | Copystar CS-1510 Copier
Black ink is full but does not print.
Did you make sure that the cart was placed well and the plastic hook secures the cart on top?
If you have used Easy Jet carts, you can stop here and give the whole machine a push to the bin!
Easy Jet carts and some other generic ink carts clogg the fine filter in front of the nozzles which cant be cleaned anymore.
The ph as a spare part is more costly than a new mfc 240c at a price discount!
But you can try this at least:
Use a new original brother carts (BK/C/Y/M). place carts and secure them! (this procedure will consume some ink!)
press menu then start bk copy then fourtimes arrow-up button. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph
and will do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy to run a special power purge.
When finished press 9 then 9. After machine is back in normal state run a test print.
If you still cant see any bk the ph cant be fixed anymore.
Jan 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Ink
Use original brother carts: Make sure that all carts are placed well and are secured. Press menu then start mono (blue b/w copy button) then four times arrow-up (tel-index?). machine should be in maintenance mode. press 7 then 6 then 4. machine will do a cart initialization and do some cleaning. Leave the maintenance mode by pressing 9 then 9 when its ready. Do a test print. If need do cleaning cycles twice.
In case you cant see mag. and cyan your printhead is defectiv and has to be replaced.
Nov 20, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Home Logo
357 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
