FixYa.com
Tags:
Intel D845GLLY Motherboard
Driver for vista (by 2 users)
posted by aryatushar on Nov 04, 2007
hey recently i installed windows vista but i could not able to find video driver for vista. Please help me........
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 29, 2008
I have installed vista but win is not installing my vedio driver i.e 64mb
Solution #1
posted on Nov 04, 2007
Not Rated (0)
cyrylthewolf
Rank:Guru Guru
Rating: 92%, 143 votes
Believe it or not...
XP drivers often work in Vista. Much as the Windows 2000 drivers worked in XP.
Go ahead and try the XP driver. Make sure you create a restore point before you do...just in case.
I have used this very driver in Vista for two of my own systems myself, so I know that they work properly. Let's hope they work the same for you.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=829&DwnldID=6107&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
You may have to do a manual installation of the hardware rather than using the setup.exe. Use Device Manager. Find the device. Select "Update Driver" and point Windows to the .INF file for the driver.
To be honest... Vista should already have drivers for this video chipset. The only problem is that it might not let you select the maximum color depth or resolution until you install the Intel driver. :P
Good luck. Don't forget a restore point!
Cyryl
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
no sound
i have problem with audio... Answer This...
Motherboards
microsoft says my os is not an...
Is there another way to get a... Answer This...
Motherboards
change the start up logo on a...
hi i would like to know how... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Beep Sound on Upgrading RAM On ...
i checked may web sites and... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
