Question about Black & Decker Jump Start System 450 Amp Instant Starting Power/ Compressor
I bought a stanley 450A jump-starter. I put the cables on correctly (red to +...and black to negative). When I turned on the jump-starter switch there was smoke and a spark. It's a 92 toyota corolla. What happened?
1984 dodge wont start has new battery can turn the key but wont do nothing
Question are you sure battery is charged ? Do this turn on head light`s to see if they work first. If they don't check that you put the battery cables on the correct post ( Red to the hot and black to negative post ) and make sure they are tight . If they are on correct you may have a bad starter. Did you change the battery because it was bad are because it would not start the car ? If every thing else worked before you replaced battery like head lights and stuff you may of just had a bad starter to begin with. Good luck
Jan 31, 2016 | Dodge Cars & Trucks
I used my Stanley Fat Max 450 Amp Jump Start System with Compressor 900 Peak Battery Amps to jump start a vehicle and accidently crossed the negative to the positive and positive to the negative. After...
I would imagine an item from a company such as this has a fuze or such to prevent damage from cross connection. The pop you heard is probably an internal fuze or overload unit going off.
They are online at samsclub for 39$ if you can't fix it.
Jul 21, 2014 | Cars & Trucks
2007 sonata thought the battery was dead so I tried to jump it off. It would not even make a clicking nosie when I turned to starter over.
First check both cables to the battery, are they cleanly connected to the starter/engine, clean at battery posts, Did you jump correctly, placing positive red on negative will give a large spark and may have damaged electric relays or fuse, best to go black on metal component on engine and red to positive side of battery. Even if the engine is locked up there will be a clunk of some kind. No sound at all means no electrical connection
Jun 29, 2014 | 2006 Hyundai Sonata
How can i know if my starter relay is bad on a dodge stratus 2001
IF STARTER RELAY BAD THE STARTER WONT MAKE NO NOISE AT ALL HEADLIGHTS WONT DIM.IF YOU CLICKING NOISE BATTERY VOLTAGE TOO LOW. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS AND USE TEST LIGHT TO SEE IF STARTER GETTING POWER.COULD HAVE BLOWED IGNITION FUSE OR FAULTY IGNITION SWITCH. TO CHECK STARTER SOLENOID FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND POSITIVE BATTERY CABLE.THEN REMOVE STARTER BUY A REMOTE SWITCH.YOU NEED BATTERY JUMPER CABLES HOOK BATTERY JUMPER CABLES TO BATTERY PUT POSITIVE CABLE ON POSITIVE BATTERY POST THEN PUT NEGATIVE BATTERY CABLE ON NEGATIVE POST. HOOK BATTERY CABLES TO STARTER USE NEGATIVE CABLE GROUND STARTER BODY AND PUT POSITIVE BATTERY CABLE ON THE LARGE POSITIVE POST ON STARTER SOLENOID. NOW TAKE REMOTE SWITCH HOOK RED WIRE TO STARTER SOLENOID POSITIVE POST THEN HOOK BLACK WIRE TO REMOTE SWITCH TO STARTER SOLENOID SWITCH TERMINAL WITH LETTER S THEN PRESS REMOTE IF STARTER SPINS STRONG WITH A GOOD KICK STARTER GOOD.YOUR PROBLEM COULD BE CORRODED WORN BATTERY CABLES. WEAK BATTERY FAULTY IGNITION SWITCH. IF STARTER DONT WORK WHEN YOU PRESS THE REMOTE SWITCH STARTER SOLNOID BAD OR STARTER ITSELF BAD.IF ALL IS GOOD. CODE SCAN CAR FOR THEFT SECURITY FAULT CODE.
Aug 28, 2011 | 1999 Dodge Caravan
I need to jump start my car but lost my manual. Are there instructions online somewhere?
If you need to jump the car regularly ... it is time for a new battery. I see you have a jumper device, attach the red or + lead from your power station to the POS or + or Red terminal on the battery. Put the black or - from the power station to the Black or - post of the battery. Start the car.
Thanks for your question @ FixYa.com
Feb 17, 2011 | Stanley Proto Stanley DPS109 Digital...
I bought A Stanley 450 jump start & I'm to charge it for 24hr. The 2 red lights are on but the green light is still blinking after 14hr. What does the blinking light mean?
not sure if you found this yet but it is actual made by Baccus Global under the stanley name.
http://www.baccusglobal.com/faq.php
Q: How do I know when my Jump Starter is fully charged?
A: All of the Baccus Global jump starters have a battery status indicator, units can have 2 - 4 LED indicators when all of them illuminate and the green one flashes the unit is fully charged.
Dec 05, 2010 | Black & Decker Jump Start System 450 Amp...
How to jump start a chevy HHR
UNDER THE HOOD IS A SMALL RED BOX OPEN THAT AND PUT YOUR RED CABLE ON IT AND THE BLACK ONE ON ANY PART OOF THE MOTOR OUT OF THE WAY FROM ANYTHING TURNING IF NOT THE BATTERY IS IN THE TRUCK BY THE SPARE TIRE YOU CAN DO IT FROM THERE ALSO RED TO RED BLACK TO BLACK
Oct 19, 2010 | 2006 Chevrolet HHR
How to jump start it
To jump start any car, you will need to have either a portable jump starter (that look like the ones found here: http://www.autobarn.com.au/products/7/45/3022812/) or have jumper leads which look like alligator clips.
To use either option, attach one side of the jumper cables to to your battery, then attach the other end to another car battery (or in the case of the portable jump starter, it will be already connected with the unit).
Ensure the correct color cable is attached to the correct battery terminal (metal point on battery), i.e. red to red, black to black.
Caution: Car batteries have a high amperage and can lead to electrocution if you touch both metal points on the battery. Always be careful when doing so and if unsure, do not attempt to do so without assistance from a competent individual.
Oct 24, 2009 | 1990 Buick Riviera
Doesn't start, hear a clicking sound
Red to red, then black to black. Negative is always off first and on last! If it doesnt turn over even by jumping, the clicking is your starter solenoid = starter motor possibly defective. One way of trying to start it, is to tap the starter motor while trying to turn the engine on. Not 100% garanteed but 7/10 times worked for me rescuing people!
Apr 25, 2009 | 2005 Suzuki Grand Vitara
Black & Decker Jump Start System 450 Amp Instant Starting Power/ Compressor Logo
65 people viewed this question
Top Black & Decker Hammering Experts
Gary Nitowski
Piyal Perera
Piyal Perera
Are you a Black & Decker Hammering Expert? Answer questions, earn points and help others
