Question about Carrier 38CKC036 Air Conditioner
COmpressor not working
Rheem RAKA-024JAZ Fan was not working but compressor was kicking in, as suggested in another forum I spunt the fan by hand and it started, I decided to let it run a while to cool the house down and planned on shutting it down but when I went outside the unit was shut down and now the compressor will not kick on even when pushing the coil down is the compressor now toast also?
  • Marty Flack
    Marty Flack May 13, 2014
    Not A carrier DOnt know how that got there?
  • Marty Flack
    Marty Flack May 14, 2014
    I have a cap and fan ordered was just worried that the compressor was now bad because it won't kick in either now when pull down coil is pushed
  • 3 Answers
Check the capacitor, if it is bulged out it is obviously bad, but I have replaced many that were hard to see whether the top was bulged out or not. If you take the access panel off (should be in the same area as the contactor you were manually pushing in) you should be able to see it. I have only had luck buying them at my HVAC supply houses (usually under $10) You need to make sure to get one that has the same MF as the existing one, if you take it with you someone should be able to match it. Be sure to discharge the capacitor of any stored electricity before disconnecting it (I would recommend calling in a professional HVAC tech if you are unfamiliar or uncomfortable at all with this procedure)
Posted on May 13, 2014
  • 182 Answers
SOURCE: carrier central ac high efficiency
usually capacitor,burnt wires or bad compressor.kill the power and check the terminals at the compressor.they have been known to burn off if the connection is loose.
Posted on Nov 03, 2008
  • 14 Answers
SOURCE: Fan blows but compressor does not run.
turn off asap! the compressor is the heart of your system, so it might need a hard start it gives it more power if that does not work be ready to pay for a new outside part
Posted on Oct 16, 2008
  • 143 Answers
SOURCE: carrier fan unit
Poke the fan blade with a stick to see if the bearings are seized up. If it turns easily, you have an electrical problem, like a bad capacitor.
Posted on Jul 24, 2008
  • 15 Answers
SOURCE: Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Posted on Jul 05, 2009
luker711
  • 91 Answers
SOURCE: the a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Posted on Jul 11, 2009
I have two units, Rheem 10 seer Model RAKA 030jaz Model RAKA 024JAZ Technician says both need to be replaced, bad compressor. Can I go with in large system or can I replace compressors in each? House is...
The probability of interconnecting two separate duct networks designed to properly distribute proper air flow with their own air handlers is remote. Is it possible?? Yes. Is it going to work perfectly ?? No. Even if it did, the noise level on a ten ton air handler would be very undesireable in a residence.
As a matter of fact, it may not even be possible depending on how the structure is laid out. A two story with a system in the attic and one in the basement isn't going to interconnect easily for instance...
Mar 11, 2015 | Heating & Cooling
I have a Rheem classic xi model RPLA-024JAZ and need a capacitor and contactor (1 pole 208/230v.) How can I find the right model numbers to buy?
JUST ORDER A ONE POLE 35 AMP CONTACTOR THAT WILL DO IT FOR YOU THE CAPACITOR YOU NEED IS WRITTEN ON THE CAPACITOR FOR EXAMPLE 35+5 THE 35 IS FOR THE COMPRESSOR AND THE 5 IS FOR THE FAN IT WILL BE WRITTEN IN MICRO FARADS,
Sep 09, 2014 | Heating & Cooling
Rheem AC raka-030jas. not cooling house. New filter, power to entire system, new batteries in thermostat, condenser coils cleaned, no ice on lines, indoor blower is working, outdoor condenser and fan
Its possible that you have too much Freon and also if the fan in the condenser is coming on you need to make sure the compressor is running too. Some of them are quiet. Grab the line and see if you can feel refrigerant running through them to see if the compressor is running.
Aug 28, 2014 | Heating & Cooling
Rheem RAKA-060JAZ trouble question
pls check for compressor shorting and relay issue in pcb
Oct 12, 2013 | Heating & Cooling
Rheem RAKA 037 JAZ
When power is applied to the motor try spinning the fan blade with a small object such as a stick, if this gets the motor going than the capacitor is faulty and must be replaced. The capacitor is located in the outdoor unit.
Jun 21, 2012 | Heating & Cooling
I HAVE RHEEM AIR CONDITIONER THAT STOPED WORKING, ITS ONLY 13 YEARS OLD.....SHOULDN'T IT LAST 15 YEARS AT LEAST MODEL NO. RAKA 037JAZ SERIAL NO. 5429m119608316 replaced freeon twice. ITS...
yes abd more like 20 or more if you take care of it. But you do not say hwat is working . you just say its not working.. does the indoor fan work? does the compressor try to start? have you checked the fuses or breaker?
Jul 17, 2011 | Heating & Cooling
I have a rheem model RAKA-037JAZ air conditioning unit and the fan and compressor will not start. The fan will operate once the blades are given a "jump" start by spinning the blades. The...
The unit probable has a dual cap, if you look it will be on the cap somewhere, go to a motor repair shop and they should have it; there can be other starting components that could be bad, do not give up on the comp. until you have extinguished all other possibilities.
Jul 06, 2011 | Heating & Cooling
The fan does not spin
If this unit is located outdoors then it is your condensor fan. Can you hear the compressor come on? If not it could be the capacitor is bad,
If compressor comes on but fan does not, it is most likely your fan.
Jun 26, 2010 | Ruud UAKB048 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
89 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
