Olympus VR310 Digital Camera Logo
Stewart Kemp Posted on May 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My olympus won't turn on. she does a quick split second flash of the screen on and then off?
Harrie
Level 3:
Top Expert:
  • Olympus Master 6,746 Answers
  • Posted on May 14, 2014
 Harrie
Olympus Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285766
Points
83153
As soon as the camera acts different form what you expect, you can "reset" any software problem, by switching off, removing the battery and memory card and then reinserting both and switching on again.
When you remove the battery, check it the contacts are clean and shiny. Do the came for the memory card. Use a bright light and eventually a magnifying glass to look in the camera, to the contacts there.
You can clean contacts with a dry cloth or cotton swabs. Never use anything sharp in or close to a camera.
Success
Olympus TG-320 camera won't turn on
It's a high probability that the waterproof seal leaked and the water is making it's way through the system shorting various components.
Diane
NYC Photo Safari
2answers
2answers
Olympus e510 hot-shoe doesn't respond...
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
TrekStor 160gb Harddrive wont turn on
Try to turn it off and quickly turn it on again in a split second.
And buy a second hard disk just in case.
Power
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
LG 42 plasma quick blank flash
use other source such as dvd , regular ant or vcr ..use other source for awhile to see if it happens on ther sources .
Power issues.
you sdaid power surge on the laptop. Thus suggests that this may have affected the camrera. I would think a 'repair' if such is possible will be near the cost of replacement. Only Olympus can advise
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
