Question about QSC Car Audio & Video
Soon as turn on my qsc mx 3000a ch 1 keep clip and ch 2 playing
  • QSC Master
  • 637 Answers
It is seeing an overload of resistance. Check your speakers to see if they are within tolerance of stated ohm factor.
Posted on Jun 18, 2014
2 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: Soon as i turn on my QSC RMX2450 the clip light comes on for Ch 2
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
Posted on Sep 14, 2009
My QSC 1500 LOUD speaker won't turn on why?
I've had QSC power amps with internal fuses in the AC power section, and I have seen the fuse holders separate from the board. These were the 2-piece (per fuse) clips that solder to the board and the fuse clips into them. I'm not sure if you are talking about a speaker, a power amp, or a powered speaker, but if it doesn't power up at all, it's probably in the AC Power Supply area.
Jul 25, 2014 | Audio Players & Recorders
Amp 5050 rmx stay in clip mode
Disconnect speakers. With NO input, if clip light remains on, take in for repair as there is an internal failure. If reducing the gain and loudness keeps the clip off, then you are probably driving the amp too hard. This is common problem when the user "thinks" they need it louder but the amp speaker combination will not deliver louder. At this point, both the amp and the speakers are at risk of permanent damage requiring repair.
Sep 22, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
I am using this amp for an intercom system. I have 24 speakers hooked up in a train fashion but I am unsure on the back of the amp where my black and white speaker wire should go, can you help me? I have...
It's depending on which speakers you are using. If you're using 100Volt speakers you can connect them on ch.1 between 0 and 100 volt. Then you are using only ch.1.
Regards,
Gerard
Oct 04, 2010 | QSC ISA 300Ti Amplifier
How can i get my qsc mx 3000 fix i think there is a problem with one of the pre amp IC or board
Closest place
AV Technology Panama Corp.
Edificio Met 1 piso 8
Calle 74 San Francisco
Panama City
Bahamas
Apr 15, 2010 | QSC Audio Players & Recorders
Qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Mar 28, 2010 | QSC MX1500A 2-Channel Amplifier
Sep 07, 2009 | QSC RMX-2450 Car Audio Amplifier
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
Need schmatic for ep2500
check preamps small parts! maybe you have change value capacitors and resistors!
Sep 13, 2007 | Behringer EUROPOWER EP2500 Amplifier
Car Audio & Video Logo
55 people viewed this question
Top QSC Car Audio & Video Experts
xxxxxx xxx
Are you a QSC Car Audio and Video Expert? Answer questions, earn points and help others
