Question about Brother XL-2610
WHy is my Husqvarna Viking 560 serger is skipping stitches????
My serger was working, but it's not now. It makes the chain of stitches when there isn't fabric, but when I go to serge fabric, it skips and then leaves large (2 inch gaps). I've changed needles, rethreaded and checked the manual. Does the looper thread go behind the needles' thread or in front of the needles' thread? That's all I can think of, but I've tried it both ways..... HELP?????
  • Ella Jane
    Ella Jane Jun 20, 2014
    EXCELLENT comment. Very specific advice and instructions. Thank you
    Sergeant:
  • 248 Answers
Here are a few things to try.
1. Make sure that correct type of needles are being used, both are the same size, and that the needle size matches the fabric weight. This is the first serger to use 15X1 needles.
2. Make sure that the needles are installed correctly and are pushed all the way up. Have you replaced the old needles with new ones, not other used ones?
3. Thread has a shelf life, it can expire over-night. Just to eliminate this possibility, replace all threads with fresh good quality serging thread (and not just another spool which was purchased some time ago).
4 It sounds like you have re-threaded the serger correctly according to manual instructions. Here is a sure fire method:
- thread the upper looper and place the thread behind the needles under the presser foot. Make sure that the thread is lying firmly between the tension discs.
- thread the lower looper (the tricky one). Check that the thread is between the tension discs as before and place the thread over the upper looper and then behind the needles, and under the presser foot.
- thread the needles, checking that the thread is between the corresponding tension discs. Place the thread under the presser foot.
5. Check stitch length.
6. Check if the problem persists with other fabric types, use two layers. If the problem occurs with only a particular fabric, then the cause is incorrect needles.
7. Check tips on both upper and lower loopers. They should be free of burs, smooth, and have a semi-sharp point.
Hopefully this will solve your problem, if not it may be time to have it inspected by a qualified technician.
Please rate how effective were these suggestion in solving your problem, it is important to me.
Posted on May 14, 2014
5 Suggested Answers
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 108 Answers
SOURCE: I was wondering if you could help me concerning my
i was able to find manual at www.ifixmachines.com
Posted on Feb 15, 2010
SOURCE: zigzag stitch problems on brothers pc-420 sewing machine
Sewing machine skips stitches
1.needle inserted incorrectly
flat side of the needle faces the shaft
round needle
groove of needle faces away from the shaft
Correct needle insertion is mandatory for proper use
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle.
Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Posted on Mar 30, 2012
  • 539 Answers
SOURCE: Serger is threaded correctly, added new needle, threads do not form on stitch finger to connect to fabric when sewing. What's up?
Is presser foot in DOWN position? Jimmy
Posted on Apr 02, 2012
How to adjust the screen display on a Husqvarna 936 serger
Hello Susan.
All the different screen display adjustments are found starting on page 10 in the manual. If the manual is not readily available, here is a free link: Viking Huskylock 936 User Manual Sewing Advisor Display Function
The screen contrast is not adjustable on the Husqvarna 936 serger.
Happy stitching.
Sewingirl/
Apr 10, 2018 | Husqvarna Sewing Machines
Skipping stitches?
skipped stitches is usually an indication of timing of hook and needle being off. The needle is not always picking up the bobbin thread. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck. Home
Feb 18, 2015 | Husqvarna Husky 165
I have a viking serger 936. I do not understand the threading for the cover stitch
http://www.sewingresourcesonline.com/product/PD1234
I have the same serger.  The produt link posted above is an awesome intrustional dvd on learning the cover stitch.
Feb 14, 2011 | Husqvarna Huskylock Computerized 936
4 thread overlock --right needle skipping stitches randomly. I've put in new needles, changed threads, etc. The stitch is beautiful just skipping a stitch randomly when sewing.
Sounds like the loopers are slightly out of line or the needle bar is twisted. Unfortunately these adjustments are not easily made. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 13, 2010 | Husqvarna Sewing Machines
Machine sews, but skips stitches. i've tried tightening the tension, but it didn't work
Good luck.
Feb 11, 2010 | Husqvarna Viking 1
I HAVE LOST MY POWER CORD AND NEED TO BUY A
You can try ebay but be sure to know what you are looking for since a lot of cords are very similiar.
3rd party vendors which might have it:
http://www.pd60.net
http://www.sewingpartsonline.com
contact authorized Husqvarna Viking dealer and they should be able to order one from Husqvarna Viking. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Sep 12, 2009 | Husqvarna Sewing Machines
Brother XL-2610 Logo
62 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
