Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
How do I change out the crankshaft seal on my JD 737 mower
  • John Deere Master
  • 16,174 Answers
You need to pull the engine. With small engines like that it is easy because the seal is in the housing and you can take the housing off and replace the seal.
Posted on May 14, 2014
JD 737 isn't getting enough fuel when the blades are engaged. It is not a dirty gas cap,fuel filter,or fuel pump. The fuel filter is never full and I can see gas dripping into the filter.
May be a vent. I have dealt with vent problems on several types of equipment. If the vent gets cloogged, you end up with a vaccum break, and pump cannot pull against it.
Nov 10, 2015 | Garden
Why can't I engage the mower deck?
Riding Mower Electric PTO Clutch Won't Engage When Hot ...
? 7:16
www.youtube.com/watch?v=wH9tZl6GzE0
May 2, 2014 - Uploaded by Steve O The PTO is relatively easy to change assuming that you can get the bolt out of the crankshaft. Basically follow ...
Sep 09, 2015 | Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
What tuff torque transaxle is fitted to the JD X300 mower?
The X300 used two versions K46BR and K46BC.
The X300R used the K46BD.
All three used the same seals.
Seal Kit
JD Part MIA880645 Non Stock Item
Can be order directly from
Tuff Torq PN 1A646099140
https://www.tufftorqservices.com/
Select Catalog Shop
Dec 20, 2014 | Garden
737 JD MOWER WHAT KEEP THE RPM FROM RAISING UP UNDER A LOAD
go 10 and 10 on both exhaust and intake thats 10 thousands with a feeler gage
Aug 27, 2014 | John Deere Garden
How do I change out the crankshaft seal on a 737 JD mower
gas or diesel ? ck out youtube look for kawasaki(gas) 23 hp motor shaft seal change and i got one up on a perkins diesel too it's for a older unit but the methods the same
May 13, 2014 | John Deere Garden
My JD JS35 mower hit a stump and instantaneously stopped. It won't start. Occasionally it will fire once. What might be wrong?
Hi, it has most likely sheared the flywheel key and thrown the timing out. Also check that it has not bent the blade or crankshaft. Regards Phil.
Jun 27, 2012 | Garden
I have a john deere 737 ztrak with a 23hp kawasaki engine. It cranks fine and runs strong. However, when the pto is engaged and begin mowing, the engine stalls. Also, the battery charge light comes on...
First. My disclaimer. I do not have first hand experience with your model mower.
Well, it sounds like when you engage the PTO the power to the PTO shorts to ground causing a) your charge light to come on as the voltage drops substantially and b) your mower to stall as the minimum voltage of the ingnition system is reached (or some other effect is at work). The clutch is might be internally shorted, or you may have a frayed wire in the PTO circuit. You may or may not have a PTO relay. If you do, it is sure to burn up if you continue using your mower. If you do not have a relay, you will definitely burn out the PTO switch. It is odd you are not blowing an inline fuse if this is the correct answer. Check your PTO circuit with a continuity tester to tell you if there is a short (or measure resistance directly with a voltmeter on ohms).
Aug 09, 2011 | John Deere 23HP VTwin Dual Hydrostatic 54"...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
116 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
