Question about Refrigerators
Diagnose problem? Screen above ice/water dispencer shows "of" where it supossed to have temperatures and degress,,,,refrigerator and frezzer arn't working.....its Samsung side by side
  • Refrigerators Master
  • 17,115 Answers
Of means OFF. Check the settings.
Posted on May 14, 2014
  • 142 Answers
SOURCE: SIDE BY SIDE FRIGIDAIRE REFRIGERATORS
Freezer door switch that tells the fridge that the door is closed might not be in contact with the door when it is closed. Safety mechanisms make it such that the water will not dispense if the fridge thinks the door is open.
Posted on Mar 08, 2008
hapndnvegas
  • 35 Answers
SOURCE: GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Posted on Mar 27, 2008
22yooper
  • 828 Answers
SOURCE: Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Posted on Jul 05, 2008
  • 958 Answers
SOURCE: sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
SOURCE: In operative water dispenser.
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Posted on Jan 07, 2009
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Freezer won't reached desired temp or make ice
Most definately you do. somehow air got in while you were away. 12 hour defrost with doors open will help.(insulation in side by side normally thick).Had one like that approx. 2 months ago but fridge was not well treated and they damaged rubber seal at water and ice dispencer area.
Jun 06, 2010 | Bosch B20CS51SNI Stainless Steel Side by...
Ice maker not making ice
i had same thing happen the line going to the ice maker was froze i too everything out of frezzer and let line unthaw for about an hour now works fine
Apr 28, 2009 | Whirlpool GD2SHGX Refrigerator
Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ice maker not getting water from water valve
CAN YOU HEAR THE WTR VALVE ACTIVATE OR TRY TO SEND WTR TO ICE MAKER HAVE YOU CHECK THE FILL TUBE INSIDE FREZZER WHEN THEY FREEZE INSIDE TUBE WTR WONT BE DISPENCE INTO MOLD
Nov 01, 2008 | Frigidaire FRS3R5EMB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
