How can I unlock an Ariston AWD129NA washer-dryer after poor handle installation?
I replaced the handle on my AWD129NA and mistakenly placed the hook facing the wrong way (i.e. inwards facing rather than outwards) and since it closed it, it won't open. I've tried accessing the lock by opening the top access panel, but I can't seem to open it. ] Is there any way I can open the handle now that it's been poorly installed? Do I have to break the lock from the inside and replace that? Any help would be much appreciated!
SOURCE: Ariston AWD 120 Door Handle is Loose
unplug it.
open the top lid.
reach down inside and feel a plastic sensor/release behind where the latch is.
towards the left center of that sensor, feel for a metallic manual release (you'll just feel the nub of it).
Push this in and to the side to manually release the door lock.
Call Ariston and complain about this common problem.
Posted on Nov 09, 2007
SOURCE: How do I open the front Service Access Panel?
The round access panel turns about 5 degrees then it pulls off. If you try to pop it off you will break it. Once it's removed there is a twist on cover to gain access to the pump guts to look for crud. Unscrew the cover (put a pan under it because water will come out) and look around for anything that doesn't belong there. When you reassemble it, there is a piece on the cover that has arrows on it pointing down. Put that on the bottom and screw the cover back on.
My guess is that if your washer is full of water, it will all drain out when you disassemble the pump guts.
Posted on Nov 13, 2007
ghappliances
  • 126 Answers
SOURCE: replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
SOURCE: Broken door handle Hotpoint WD860
Managed to work it out, you have to slide the outer door case away from the handle locking mechanism, slide left and move away (after undoing the 6 screws on the inside) :-)
Posted on Dec 05, 2008
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
What does f8 Mean?
F08: Resistance Missing or Pressure Switch stuck on Full Found
  • Overhaul CN1
  • Overhaul Resistance Connection
  • Overhaul Pressure Switch Connection
  • Replace Resistance
  • Replace Pressure Switch
  • Replace Card
Dado
Jan 11, 2015 | Ariston Technologies AWD120 13 lb. Washer...
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Door handle on ariston awd12s has broken how i can i get the door open
open the table top of the machine and release the door switch by any flat screw driver
Jun 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Will a new handle fix our problem?
Thanks for responding back.
We decided not to go for the dryer.
thanks again.
Jan 20, 2009 | Ariston Technologies AWD120 13 lb. Washer...
unplug it.
open the top lid.
Nov 04, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
