Question about Gateway One ZX4300-41 (PWGAW02017) 20 in. PC Desktop
I bought a used motherboard from ebay.After a month it turned black screen again so can u help me
    Sergeant:
  • Gateway Expert
  • 464 Answers
So you replaced the motherboard.
Well the systems are like laptops so you need to check LCD cable inverter and the LCD screen.
eres one that had a motherboard problem but the screen seems ok.GATEWAY ZX4300 01E ALL IN ONE AS IS FOR PARTS <<< i buy part as is when it system don't power up because its not screen related.
or pay seperate
Gateway All in One ZX4300 41 Inverter Board
Gateway All in One ZX4300 41 Inverter Board Cable DD0EL2IV000
Gateway All in One ZX4300 LCD Video Cable DDEL2CLC000
check if the system is compatible.
Posted on May 13, 2014
I use samsung netbook nc110, it works normally until I play a video and the screen goes black and won't come back to normal. I bought it 9 months ago and this begin happening last week. Any solutions?
You can use an external monitor to test it. If the external screen does not display anything, then your GPU and or motherboard is dying. If your netbook works good with the external monitor, then your screen is dead.
You can check the operating system and application using this Norton Utilities:
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Mar 09, 2014 | Samsung NC110A02 Netbook
Black screen
what operating system are you running??
Mar 11, 2008 | Acer Aspire 5610 Notebook
Motherboard change
if your pc will boot try to update the bios ..(.it may help) the board you bought might not have the correct bios flashed on it or its an older flash...
Dec 10, 2013 | HEWLETT-PACKARD 504466001 HP TouchSmart...
My Cisnet PC has a new motherboard (only been used 5 months) and has froze up on me twice the last week...it won't turn on again unless I let it sit overnight...this last time, though, nothing com
Could be a possible hardware problem. When you say new motherboard, was there an issue with your old one? Were you given the exact same model?
Also, maybe an issue with your power supply.
Oct 19, 2012 | ZT Group Cisnet PC Desktop
VIDEO PROBLEM SAMSUNG LN46A630 I have a SAMSUNG LN46A630, after turn on the TV around two hours the screen goes black - the video disappear, some time the video come again the sound doesn't go, you can...
The Tuner signal board have intermittent problems.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish Tuner signal board for the replacement.
Oct 16, 2010 | Samsung LN46A630 LCD TV
Power problem
first dint buy (not original) adapters and replace the original adapter try to charg battery
Jun 22, 2010 | HP Compaq Motherboard
No picture, good audio. Replaced motherboard...
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Feb 12, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
BSoD, Garbled Screen, Boot Failure.
If you are getting garbage on the screen before windows tries to load the laptop probably has a bad motherboard.
It's possibly only the video output is going bad on it, try hooking it to an external monitor and see if you get the same weird stuff on that screen.
Good luck, let me know how it goes
Nov 15, 2007 | Compaq Presario X1000 Notebook
Syntax k7sv266ad
I had this exact problem with a newly bought motherboard and it turned on but the screen was black, also I noticed once it turned on it wouldn't turn off, (Am wondering if this is happening to you) the motherboard was fine as it is in the other room now working away, so dont get rid of it just yet. Most new motherboards require additional power to the processor from the power supply, through a four pin power cable, which should be availble with the newer power supply units having (number of pins for you motherbpard power supply) + 4 (which is the 4 pin J-connector) printed on the packaging. If this is connected and you are still having problems which for me was the case, then you will have to try a different approach. Cutting the chase, the problem I had that produced similar effects of screen being black when the motherboard was powered on, was to do with my case. It was one of those flimsy aluminium foil types. I came to this conclusion by taking my motherboard out of the case and hooking it up to the cases power supply on an insulated surface such as a cork mat. It then worked fine again. So I bought a good qulaity case with a new power supply just to be sure, hooked everything up and hey presto it was fixed. It turned out that enough power couldn't get to the board as the case was shorting its supply. Hope this helps.
Jan 29, 2007 | Syntax SV266AD Motherboard
Gateway One ZX4300-41 (PWGAW02017) 20 in. PC Desktop Logo
91 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
