Question about Mtd Garden
Model 13AN601H729 mower deck will not engage spring and cable have tension but not on belt.
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
SOURCE: i have a ranch king (purchased at rural king)
Did you Call Rural King? They should have someone there that can tell you. They also will fix it if you want them to for a fee. They have very good customer service.
Posted on Apr 29, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 376 Answers
SOURCE: replaceing mower deck belt on 20 hp 42 mower model
Are you refering to the spring attached to the end of the cable that runs up to the lever on the dash to engage the blades? All you needed to disconnect was that cable on top of the idler arm that's held in place by a 'hairpin' and the left pulley cover to put the belt on.
Posted on Jun 06, 2009
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Sep 01, 2014 | Garden
Blades won,t disengage
Assuming this is a lever actuated deck (not electric p.t.o style) I would be checking the belt pivot tensioner assembly which the cable would be hooking to a lot of times moisture will get between the pivot and the deck and rust up not allowing the heavy return spring to slide the pivot back removing the tension from the belt. If you spray the pivot with a good lubricant and hand work the pivot tensioner back and forth it should loosen up. Usually it's the other way around and the 1st time of the year you use it you can't get it to engage.
Jul 13, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro zreo turn lawn mower... mower runs but won't go when engaged. found a large spring broken?
This spring is the tensioner for the drive belt. visit www.arcolawn.com to look up your model and get the parts shipped to you.
I recommend a hook or rope to install it.
Joe
Feb 12, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard Machine tractor drive deck belt failure
i need a diagram of tensioner springs on yard machine deck 1998 42inch
Aug 11, 2009 | Yard Machines Red Edger
Craftsman 42 inch deck won't run
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 18.5 riding mower when I engage the blades to cut the blades turn But they do not engage NO Power.Blades Turn But Not enough to cutthe grass.
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
