Question about Frigidaire GLRT184RA Top Freezer Refrigerator
Frigidaire Model glrt184ra, I have to put a box fan behind the fridge or it overheats and the freezer starts to get warm. The fridge works always. The unit is hot between the fridge and freezer door. I understand that the fan in the back is not working but I can't seem to find that specific part to order.
  • 957 Answers
Order the condenser fan
Posted on May 13, 2014
Testimonial: "Wow.....must be a language barrier."
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
rpbuice
  • 161 Answers
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Posted on Dec 22, 2008
  • 10865 Answers
SOURCE: Freezer not cold enough
Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
Posted on Feb 06, 2009
  • 531 Answers
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
Posted on Apr 02, 2009
  • 260 Answers
SOURCE: Frigidaire side by side fridge/freezer
Try checking the evaporator fan. The blades are just pushed on and sometimes may work itself up or down and plastic fan could be rubbing.
Posted on Apr 09, 2009
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Apr 22, 2012 | Frigidaire Refrigerators
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Freezer cold but fridge warm
first leave it off for 24 hours, and then put it back in operation. if its doing it again , then chck the heating element, defrost timer...
Apr 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise behind frezzer while refrigerator is running...
There is a fan responsible for 'stirring' the air and distributing it partly to the refrigerator and the sleeve bearing is probably worn and allowing the blade to hit or just vibrating enough to cause the noise.
Sear's website is linked to their parts department and they have a huge library of line drawings for most brands of appliances which can help locate parts in an appliance and often the required parts can be purchased through them for many models besides Kenmore. If they have yours listed, you should be able to tell how much work it is to access the fan.
Go there and enter your model number to see how your luck is today.
Feb 22, 2010 | Frigidaire GLRT184RA Top Freezer...
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Jul 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Frigidaire GLRT184RA Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
