Question about Homelite Consumer Products Backpack Blower/Vac, Carb
4400watt generator will not start plug fireing and getting gas
    Sergeant:
  • 458 Answers
As you pull the starter cord do you feel compression? If not piston,or rings or cylinder or valves defective.
Posted on May 19, 2014
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Generator wants to start. It fires for a couple of seconds then shuts down.
there will be a oil level control unit on the engine sump that has a habit of failing on a regular basis
test it or replace it.
Jun 22, 2015 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
One cylinder not firing on generator
If you have spark and compression and it not firing then you must not have fuel. the fuel is fed from the demand regulator thru the intake independent for each cylinder. Check the intake and make sure that the NG/LP pin is all the way to the NG side.
Jul 21, 2014 | Generac Guardian 20kW Model : 5875
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
May 25, 2010 | Briggs & Stratton Power Products 5,550...
I have a Gen Power 10hp OHV Briggs & Stratton which is very hard to start. I have changed the spark plug, taken the air filter off but will not start.
I recently had trouble with my own generator. My situation was that the old gas left in the unit smelled more like lacquer than gas, the generator had not been cranked in over a year, and it simply wouldn't even attempt to fire when pulling the starter cord.
I checked the oil level, and drained and replaced the gas. I applied liberal amounts of carburetor cleaner into carburetor. The generater would briefly fire with cleaner in the carburetor. I also removed the spark plug, grounded it against the chasis, and observed good spark when I pulled the cord. This left me to believe gas simply was not getting into carburetor.
I removed the bowl and saw it was full of gas. With a container ready to catch any gas, I opened the valve near the tank and observed liberal amounts of fuel spilling from where bowl mounts to carburetor. So, good gas flow to bowl confirmed.
Using carburetor cleaner and compressed air, I blew out and attempted to clean every orifice I could see. I also checked the float assembly and saw the needle valve that allows/blocks fuel into bowl was operating freely. Reassembled everything, and still wouldn't start.
Took the bowl back out and gave the float assembly further inspection. On my unit, there is a large hole in the center of the assembly where the "perforated brass straw" should be sucking up gas. In the bottom of that hole I discovered a brass plug. I didn't spot this plug before because is was totally encrusted in trash. I was able to remove the plug. This thing is about 4mm long and wide. In the center of this plug I discovered a completely clogged hole. I had to actually scrape it clean with a metal pick, being careful not to damage the metal. I then followed up with lots of carb cleaner and compressed air to make the plug and the tiny hole completely clean. I replaced the plug, replaced the bowl, and the generator fired right up.
I wanted to share my story with you because of the frustration I went through taking my carburetor off at least 8 times before finally discovering this tiny brass plug that no one on any of the forums has ever mentioned.
Apr 30, 2010 | Briggs & Stratton Briggs Stratton 6200...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
