Question about Neff Refrigerators
I cannot turn on the light in my neff freezer/fridge. What can be wrong?
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
  • 1462 Answers
SOURCE: my neff side by side
7 is the coldest and 1 is the warmest
Posted on Sep 03, 2008
tborn6
  • 700 Answers
SOURCE: how do i switch off freezer part of neff american fridge freezer?
turn off the thermostat on the freezer and the refrigerator and that should shut it all down.
Posted on Apr 03, 2009
  • 5 Answers
SOURCE: Neff K9724 Fridge Freezer with water in the fridge drawers
sounds like a thermastat problem or maybe your drain away hole is blocked
Posted on Apr 25, 2009
iwillfixforu
  • 619 Answers
SOURCE: Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Posted on Feb 04, 2010
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Neff Fridge Freezer K3965 Freezer is working but the fridge is not
This is either a defrost problem or the evaporator fan is not running. The way to check is to open the freezer and do two things. Listen to see if the fan is running, if not and you hear the compressor in the back going then the fan is the problem. If the fan is running then look at the freezer wall and see if it is covered in frost. If so, you have a defrost system failure and either the timer, bi-metal or the defrost heater has gone bad.
Sep 05, 2012 | Neff K3965XO Side by Side Refrigerator
Freezer working fine,but the fridge dose'nt seem to be working not cold at all.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 12, 2011 | Neff K9524X4GB
Fridge/freezer . freezer ok but fridge not working even tho light comes on
check damper control, also check freezer side, if there is frost built up it could be 3 things, 1. cold control, 2. heater, 3. thermostat.
Jul 02, 2009 | Neff Refrigerators
How do i switch off freezer part of neff american fridge freezer?
Apr 03, 2009 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Refrigerators Logo
16 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
