Question about Sharp Aquos LC-52SE94U 52 in. LCD HDTV
What is the reason for the ceramic fuse in the power board blowing?
  • 2,509 Answers
Something downstream is drawing excessive current, Disconnect boards to isolate.
Look at capacitors to see if any have bulging tops
Posted on May 14, 2014
I've got a Toshiba 40E200U1 that blows the fuse as soon as it's plugged in. How can I diagnose if there is a problem with the power board?
Take it for professional diagnostics and service. It is cheaper in the long run. Fixya is full of people that swap out boards they think need replacing and change all of them, and still not fix the set. You have a dead short, it may be in the power board but it could be on any board that is connected to it. The course to be a television technician is 2 years full time.
Feb 12, 2018 | Toshiba Televison & Video
No lights on bosch washing washer
check to see if there is any power going to the main board and if not you have a problem with a plugin, but if power going to main board then you have a fuse blowed, ie ceramic fuse.
May 05, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Ceramic fuse blows on power board
the power board is shorted and will need replacement. Yo can get the power supply board from www.tvrepairworld.com
Mar 16, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
Magnavox Television
There is an 8amp 250v 5mm x 20mm ceramic slow blow fuse on the power supply board inside the TV. The picture below shows the board with the fuse circled in yellow. If you had a big enough power surge it may have damaged other parts of the power supply beyond the fuse. Look for burn marks on the power supply board when you replace the fuse. If you need additional information just let us know tech@ccl-la.com
Jul 25, 2012 | Magnavox 40MF430B LCD TV
Need to find the ceramic fuse for my samsung 50"
Hello Dyan, Hi you can find one at any electrical or electronics shop that sells spare parts, But mind you the reason why the fuse blows in the first place, have the power supply board checked for shorts such as a shorted switching regulator. If in the event the replacement fuse blows again, there is definitely a shorted part. Have this checked by a technician.
Feb 12, 2011 | Samsung FPT5084 50 in. Plasma HDTV
I need to replace a fuse on the main board and need the part number for it.
hi there.
fuses do not have part numbers,rather board reference numbers,for example,-F201-.
if it is a glass fuse,or white ceramic fuse,the rating is on one of the silver coloured end caps.
eg.t4a or t3.15a. the suffix t means time lag,or slow blow, and a f means fastblow. the rating numbers after the suffix relates to the amps the fuse is rated in.
remember fuses seldom fail without reason nowadays!!!
Sep 28, 2010 | Televison & Video
My Nautilus C2150 treadmill just stopped for no reason and now will not turn back on. Looks like a fuse blew, but can't locate a problem and the electrical looks ok. Any ideas?
have you remove the motor shroud? unplug unit first, you should be able to see a 15 amp ceramic fuse ( white colored) if you have a multi-meter check continuity if open replace it and if it blows the fuse again then the motor control board has a direct short to ground and the board will need to be replaced. Just wondering has this unit ever been serviced or any maintenance done on it? if not! suggest you do so.
Feb 27, 2010 | Exercise & Fitness
Fuses blown & controller card fried
Take this from a 4 board and 9 fuse owner.I believe the ceramic thermal fuse does not blow quick enough and during voltage spikes,or under a load cause overheating of the control board.All my boards had burnt marks on the back of the board(apposite where the 4 prong plug goes).I purchased a new board ,new ceramic fuse with the wire.They say the wire must be replaced too.(Ebay under Whilpool dishwasher fuse 14.00) Next on Ebay I purchased a 15 amp marine push button circuit breaker which I mounted in the side of the front panel.Split the one leg going to the ceramic fuse,run it to one of the legs of the breaker and run the other side of the breaker leg back to the ceramic fuse.I know someone out there is saying you don't need the ceramic fuse if you have the breaker in the line.Humor me.Lets say you get a large surge that fries the breaker closed as in a lightning storm.The ceramic fuse may save the day.Since I have set ours up this way the breaker trips once in a blue moon.Reset it and your off and running again.Oh and don't bother calling Whilpool(makers of Kitchenaid) You can't get anywhere with them.Now if for some unfortunate reason this doesn't solve your problem,don't throw away that dishwasher.Remove the upper and lower baskets,bolt them to the trunk of your car and the next time you go to the car wash bring your dishes with you.LOL
Jul 26, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
42" LCD HD TV keeps blowing fuses.
A ceramic fuse stands up to heat better than a non-ceramic fuse. I'm no pro, but it sounds like your power inverter board maybe bad. There are replacements out there. Good luck
Jan 18, 2009 | Vizio L32 32 in. LCD HDTV
Sharp Aquos LC-52SE94U 52 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
