Question about E-Machines eMachines Desktop PC
Dvd burner error
I can analize a dvd however when I put a blank dvd in, I get a drive is in use with another application error and will not copy. I check the properties of the drive and cant seem to see anything out of the ordinary. This is doing the same issue no matter what I try to copy...
  • Hank May 11, 2010
    Hi, It sounds like you may have an application running in the "background". Please let me know what copying or media software you have...for example, nero, roxio, power producer etc. Hank
  • 428 Answers
I think windows CD burning utility is accessing your drive
U have to disable it. And remove it from the startup
it will go like "imap..."
Go to start menu and get run box
type msconfig
then hit enter
The go to startup tab
check whether there is a similar name. If so, untick the box
Thanks
Hope this will help. If it was satisfactory please rate the answer
Good Luck
Posted on Jun 23, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 194 Answers
Uninstall the dvd drive and reinstall it if that does not work update the firmware of the drive or delete the upper and lower filter from registry editor and DONOT FOR GET TO RESTART THE SYSTEM
I put a dvd in the dvd rom and blank dvds in the other and hit copy and it goes to preparing and the says that the source is not ready.
The "Source Drive Not Ready" error message indicates a problem with your master disc. There is a function on the duplicator called "Prescan" on the duplicator that can check your master disc to make sure it s a "good" disc suitable for duplication.
Hope this helps and if you have any other questions, comments or concerns, please contact us @ 877-686-8868 x208 for technical support.
EZ Dupe Technical Support
Oct 14, 2010 | EZ Dupe (EZD1TDVDNEC) DVD±RW Burner
Tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
Step1. Select DVD Source
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 | Computers & Internet
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
My combo DVD drive will burn a CD, but when I put in a blank DVD it just opens the drawer and says to insert a disc. Windows XP.
If it is in fact a Teac CD-Rewritable W58E CD-RW Burner, this will only burn CDs and not DVDs. If you put in a blank DVD you will get this error. You will need a burner that has DVD burning support.
Jan 14, 2010 | Teac CD-Rewritable W58E CD-RW Burner
LG 18x SuperMilti DVD Burner DVD=/-RW/DL/Ram Oem
Depends what software you are using to burn. Use Nero. then select dvd or cd or whatever. You must state what you are burning onto - you cant create a cd then put a blank dvd into the drive - common sense
Aug 15, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Burning problem
When you open Nero select copy dvd. Select the dvd-rom as the read drive. Put the dvd to be copied in there. Select the dvd-rw as the write drive and place a blank dvd r or dvd rw in it the select copy.
Mar 01, 2008 | LG GSA-H10N DVD±RW Dual Layer Burner
DVD writable media not recognized by drive... shows up as "Blank CD"
lol a blank DVD cant be opened directly in Win xp, you need to use a DVD burning tool... for your laptop did you check you the DVD-ram reads cd's also?
Feb 03, 2008 | LG GSA-H22N DVD±RW Dual Layer Burner
Dvd decripter
its looking for a empty disk.
Jan 13, 2008 | HP Media Center m7060n PC Desktop
E-Machines eMachines Desktop PC Logo
66 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
