Question about Haier HEATER CPN10XH9 Air Conditioner
Celiera 51GW 18000BTU mini split a/c heat, water collects on top rear coil and drips into fan housing and comes out bottom
  • jay russell
    jay russell May 13, 2014
    Not Sure Why my problem was file under Haier Heater CPN10XH9 A/C because it is a Celiera model 51GW -- maybe it is same thing -- anyway if i leave set on 77 all works fine -- when in 5 minutes of turn down to 75 water comes out the bottom of unit.
  • 23 Answers
While cooling, water is supposed to drip off the evaporator coil and flow out the unit. That's a feature of air conditioning. You get a little bit of control of where the water drips to by installing tubing to conduct the water wherever you like, unless the outlet port is plugged up. Poke a toothpick up it and see if that unclogs it.
Posted on May 26, 2014
Where should the drip trays be? Condensation dripping into fan housing.
I've seen systems that pull air through the condenser coil into the "squirrel cage" fan and use the heat from the condenser coil to evaporate the water dripped into the fan housing. They're designed to operate that way...
Nov 06, 2015 | Heating & Cooling
Senville mini split heat pump is stuck in defrost mode
Did you find a solution to this? as I now have the same problem???
Dec 31, 2014 | Senville 18000Btu 21 Seer 12.5 EER...
Leaking water
sounds like the drain is blocked or possibly the drip tray has a crack in it
Aug 01, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Hi there is water collecting in the bottom of the fridge. Have defrosted fridge/ freezer but water still collecting at bottom of fridge. Thanks
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Mar 12, 2011 | Refrigerators
We are trying to find out what an E4 on a Celiera
Does anyone know what does that means
Mar 30, 2010 | Heating & Cooling
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
STANDING WATER ON TOP SHELF
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Freezer ice
Jan 08, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Haier HEATER CPN10XH9 Air Conditioner Logo
78 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
