Question about Kenmore 72129 Black Countertop Microwave 1.2 Cu Ft, 1100 Watts
Kenmore 721 microwave, no power
It was working and potato done, when I went To take potato out lite didn't come on and no power to it. I did try the outlet
  • 28 Answers
I have seen many of these - Hopefully you do not have security screws holding the cover on the main body of the microwave. If you do, then you will have to find a special Security Tipped Screwdriver to remove the cover screws - typical is a torx with a security pin in the center of the hole - you likely will not be able to remove them otherwise. If you do not security screws, then simply remove them from around the back and likely one on the left side and slide the cover off the back of the unit. There is a lip that locks the cover to the frame. Typically on top where the power cord enters, is a small circuit board with a fuse holder, with again typically an ABC20 Amp slo-blow fuse - if you can't find a 20 Amp you can likely go with a 25 Amp fuse - If you have a meter, check the fuse for continuity ( most times you can't see inside this fuse and a meter will tell you if the one you remove is good or not).
Watch your hands - plug the unit and see if you have a display - then that's it - slide the cover back on, it locks on along the top and both sides and put back the screws
Posted on May 14, 2014
  • 43 Answers
SOURCE: microwave no heat
The "HUMM" indicates a breakdown in the High Voltage Side. The loud "POP" was the breakdown. You have only four Components in the High Voltage side.
1. High Voltage Transformer. You can eliminate this as the problem. Why? If it was the problem it would have blown the line fuse, and would have given off a burned transformer smell.
2. High Voltage Diode. Usually will Burn or Pop when shorted, but will then OPEN the Circuit and there is no "HUMM".
3. High Voltage Capacitor.This is the Silver Can with the two terminals on top. It can SHORT internaly between the plates (the two terminals) and give the "HUMM".
4. Magnetron. This is my number one suspect. A SHORTED Magnetron.
Posted on Feb 03, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: kenmore microwave #721-89941-1490
There is an internal fuse, plus one or two thermostats or thermal cutouts.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
Posted on Jul 01, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Start button on microwave does not work
Some numbers are missing off that model number. Would that be model 721.62622200?
(If not, please reply back with the correct model number off the tag)
If it's cooking with the programmed buttons, but Start is not working, it sounds like the keypad has failed.
The keypad for model number 721.62622200 is no longer available as a separate part.
So you'd have to buy the entire controller assembly, which includes the plastic frame, keypad, and circuit board, etc.
It is part # 4781W1M307A and it runs $110.10 at the Sears parts Web site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
SOURCE: kenmore microwave model 721-63252301 - no heat
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Posted on Jun 06, 2009
Kenmore microwave 721 night lite not coming on.
Check the fuse. If it's OK then you have to check the transformer in the system board also the Hv transformer and magnetron
If you wish to get some details about repairing microwave oven then how the link
www.electro-medical.blogspot.com
Jun 29, 2016 | Kenmore Microwave Ovens
Kenmore microwave Model #721-80019401
sears parts direct paste the whole URL below in your browser
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Microwave-Parts/3651W1A022B/0022/721/Model-72180009401/0582/0123370?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50026727&diagramPageId=00001
Aug 28, 2014 | Microwave Ovens
Kenmore microwave oven model 721
On the link below is the list of Kenmore microwave oven model manuals starting with 721.Click on selection to download.
www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+micicrowave%2Fhood+combo+-+7218924680
Hope this helps.Thanks!
Jan 07, 2012 | Microwave Ovens
The microwave runs and sounds normal, but it does not heat up the food. (We did run it at 100% power a few times, with no heat up) Do you have any suggestions to what the problem could be? We purchased...
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. you said your unit has power, and things lite. Then it is more likely you have a control/switch problem,
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kenmore 63252 Microwave Oven
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
Kenmore 721 microwave fan turns on by itself
I have the exact same problem with my Kenmore Microwave model 721 that we bought in October of 2005. The Fan will just randomly turn itself on even when we are not cooking. It has been doing this for the last few months and is starting to become more frequent. There is no way to turn it off except to unplug it for several hours.
Was there a recall for this defect ?
Apr 25, 2009 | Kenmore Microwave Ovens
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
Kenmore 72129 Black Countertop Microwave 1.2 Cu Ft, 1100 Watts Logo
70 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
