Question about Bayco Night Stick NSP-1136 LED Night Stick Flashlight
How do i open the light?
I need to add batteries to my Bayco Night Stick NSP-1136 LED Night Stick Flashlight
  • 2,509 Answers
The side clips off
see here (scroll down page) and thank you to webbikeworld for the excellent review
I think I'll buy one for myself! Bayco Nightstick Flashlight Review
Posted on May 14, 2014
Testimonial: "I greatly appreciate your help. I was doing it all wrong. It was difficult to see the black arrow on a black flashlight. It was only after I followed your advice that I saw the arrow. Thanks again.It solved my problem."
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
When my E2d. Ed defender. 200 lumens flash light is turn on it act like an strob light how to stop it or is it a weak batteries
No, that is a 'feature'. It is for signalling or blinding an attacker.
This is the instructions for the 500 lumen version but it will be the same. Nice light, I run Fenix Tactical. Strobe is usually gained by switching on and then half depressing the button and holding. If this doesn't work, contact Surefire direct.
The E2D LED Defender® Ultra is a compact 500-lumen flashlight featuring dual-output capability and self-defense enhancements. Utilizing a virtually indestructible high-performance LED and a Total Internal Reflection (TIR) lens, the E2DL Ultra is activated with a pushbutton tailcap click switch that also selects output levels: press or click once for a high-intensity 500-lumen white-light beam-ten times the light needed to overwhelm the night-adapted vision of an aggressor. Return to off and press or click again within two seconds for a 5-lumen ultra-long runtime low beam that's suitable for navigating at night or performing close-up tasks for hours. The Defender's crenellated Strike Bezel® provides further defensive options should the need arise. Slender and powerful, the E2DL Ultra is an ideal everyday-carry light.
Jan 08, 2016 | Surefire E2D LED Defender Flashlight Max-...
How do you open the Sylvania model no 72032 rechargeable flashlight to replace the battery and light bube?? Thanks
This is from the Sylvania site
  • Dimensions: 2.4" long x 1.7" diameter
  • Light Source: 0.4 watt non-replaceable LED
  • Internal Battery: Sealed Ni-MH 3.6V 110mAH rechargeable battery
This look like it is not replaceable - amazon sells them fairly cheaply
Oct 04, 2014 | Camping, Backpacking & Hiking
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
Flashlight
some times ,especialy in a salt air environment, the metal contacts that typycaly run along the inside of the flashlight tube,become tarnished or corroded.I suggest srips of 120 or so grit sand paper over a popcycle stic of steel wool,twisted on a stick to make a brush.note: use of anti rust oils or other solvants will losen some,But must be then cleaned for good battery connections,all poles should be clean & dry.
Feb 13, 2013 | Energizer Weather Ready 2 LED Compact...
Anyone know a good LED flashlight for camping?
you dont have to spend alot of money on led flashlights. they range from 1$ to well over 100$, In my experience and back ground. I prefer to keep several less costly ones than to spend way to much money on high dollar lights. befofe led i cant count how many mag lights i purchased or how many were lost, borrowed or stolen it depends on what your looking for and what options you want. i like to have several 1 to 2$ ones. and some that have features like position switch. for 1 led .3led or all led lamps working. or lights that have a spot light on the end and cluster leds on the side for area lighting, in my personal opinion if your going to hang on to it you cant beat a 4 or 5 D size mag light. take in to consideration they have led models now and also led conv. kits available for ones that have bulbs in them. but note you cannot focus your beam as wellwith led on mag lights. any way the main problem i sure you and any one who has owned small aluminum led flshlights has delt with the flickering hiting them and unscrewing the ends twisting back and forth to get the light to come back when you need it most. easy cure aluminum sucks as an electrical conductor. dielectric grease is your best friend. anywhere you have any connections such as the threads on the alum. flashlights. Also very important general purpose elect. conn. ac or dc and absoloutly if you own a boat please remember any elect. conn. and most important when you connect different types metals copper, lead,brass alluminum,tin galvanize,stainless,gold they all will fail lead to corrosion and or lose conductivity.and lead to damaging or ruining minor or major equipt. remember if your repairing boat wiring for instance and possibly replacing damaged equipt. having correct guage wire correct fuses for what amperage a curcuit or piece of equipt. needs. If you have corrosion at the end of your wire terminals and your fuses and fuse blocks. it will fail......so if its a flshight , acar or boat motor .airplane ect battery, if it conducts electricity clean it ,use dielectric, not wheel grease dielectric grease it conducts electricity. and try this on your inexpensive aluminium led lights. dollar store led flashlights work fine or any where you see them on sale. if they come with batterys most likely dispose of them. dont skimp on batterys. all quality batterys have a shelf life of several years. on sale aa and aaa i look for duracells or equivelent in 24,36 or 48 packs. i allways have some with me and share them with people in need. and thats another reason i keep a few cheap flashlights with me . even when i riding my HD Road King a simple flashight given to someone on the side of the road can be the gift at tjhat time that they will never forget. i apoligize for rambling . but im not typing im just talking . the typing is being prefom by dear friend xxxxxxxx I think I am .more than a dear friend and if you keep your hands and mouth off of me for a little while. I would have been done much sooner. and you might no what I actually typed. HAPPY HOLIDAYS everyone from Liz and Rick or as he likes call me LIck IT Ziggy
Dec 14, 2011 | Camping, Backpacking & Hiking
Loosing anti freeze 2001 tauras did pressure and head gasket check both passed what can it be
I own a 2001 Ford Taurus and two years ago it was losing anti freeze also. Found out that the plastic recovery tank located in front of right strut mount on fender well, had a small stress crack. It only leaked when engine was at opperating temperature. If that is not the solution, check all your spark plugs for a green-ish or yellow-ish color you have a cracked head. If they all have a light tan to dark tan color (on the white porcelin) you're good. One final check would be the crankcase oil. If the oil on the dip stick has a creamy look to it then your leak is in the intake manifold and also if the oil is oddly over full. If all these inspections turn up good you then have a external leak and need to have the engine at opperating temperature and park it on a clean surface over night. Inspect the engine compartment, engine and the floor with a LED flashlight not a regular bulb flashlight. The LED light will make the antifreeze slightly glow. If the heater core is leaking, the antifreeze will run out the air conditioning condensation drain hose, check with LED light.
Nov 22, 2011 | 2001 Ford Taurus
Flickering LED flashlight
It sounds as if the connections in the back of the radio may not be continually connected to the contacts on the charging base. You might want to make sure that the radio is properly loaded in the cradle of the charging stand. The reason why the lights 'flicker' is because if your power goes out, the light on the radio will come on when it detects no power to the charging base. This is a feature to many new emergency radio gadgets. Imagine a storm rolling through your area and the power goes out in the middle of the night. Your Vector radio's LED lights come on so that you aren't searching for the radio in the dark.
Jun 23, 2007 | Vector VEC438 AM/FM/Weather Radio
Bayco Night Stick NSP-1136 LED Night Stick Flashlight Logo
171 people viewed this question
Top Bayco Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Bayco Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
