Question about Retail Supplies
How can I fix the error 85
When you measure the distance the device gives error 85 and low signal
2 Suggested Answers
laughton5983
  • 2192 Answers
SOURCE: when I use the fatmax to measure a distance, it gives the answer in inches. Is there anyway that I can reset/program the fatmax to give me the measurements in feet
Yes press and hold the units button for more than a second until the desired units show up
Posted on Apr 25, 2017
WHY DO I LOSE MY CONNECTION TO THE NET WITH MY CELL-C HUAWEI E1752 3G USB INTERNET STICK BEFORE MY ACTIVE DATA BUNDLE HAS DEPLETED?
If the device has worked for you in other locations, the most likely answer is that you have low signal strength from your network carrier to your device. To test if low signal strength is the problem, try moving your laptop to another location, closer to the cell tower you think might be servicing you to see if it starts working. If your laptop connect software has the ability to show you the signal strength, look to see how many dBm the signal strength is. The larger the negative number, the worse it it. Below -85 dBM, you will have frequent drop outs.
-75 to -80 dBm should give you usable results. -65 dBM and lower should give you very good results. If you can only find the strength in bars, 1 or 2 bars is bad, 3 bars marginal, 4 & 5 bars useful to good. You can buy repeater devices which pick up cell signals and rebroadcast them, making them stronger for you laptop to pick up the cell signal. They usually have an external antenna port which you can put outside and high to help pull in the signal. Trees, hills, and rain all block and lower the signal strength between you and the cell tower. Distance is also a big factor.
Jan 06, 2015 | T-Mobile Huawei T-Mobile Webconnect USB...
Leica disto
Low battery. Mine does that when batteries are too low to operate the laser.
Aug 20, 2013 | Optics
I have 85 el camino with a th350 which was recently rebuilt. The shop after numerous attemps could not adjust the linkage correctly. I only had park,neutral, reverse and drive. I could not get it into...
The linkage ratio is off. This is the measurement from the center of the shifter shaft (the shaft that comes out ot the transmission) to the center of where the linkage cable/rod attaches to the arm that bolts to the shifter shaft. This distance needs to be shortened. THis will allow mre movement to give you 3nd and low.
May 02, 2017 | 1985 Chevrolet El Camino
The ads for this device state that it uses the Pythagorean theorem to figure the distance of a 3rd side, if you can measure the other 2 sides. I How do I use this feature?
1) There is a big difference between Bosch promo manual and Bosch operation manual:
2) Online promo manual says: Combined Indirect/Pythagoras for measuring total height from a distance
http://www.boschtools.com/AboutBoschTools/RequestProductLiterature/Documents/2010%20Catalog%20PDF/2010%20Measuring%20Tools.pdf
3) Online operation manual shows no instructions for Pythagoras measuring.
And shows no button for displaying E value or height.
http://www.engineersupply.com/images/bosch-tools/Bosch_Digital_Distance_Measurer_130k_User_Manual.pdf
4) Operation manual shows:
Length Measurement** and tells you to measure the height while promo says tool will calculate height E
Area Measurement*** shows rectangle only and not triangle
Volume Measurement
Area or Volume
Rounding of Large Calculations
Continuous Measurement (Tracking)
5) I would contact Bosch directly:
http://boschtools.com/Service/ContactUs/Pages/default.aspx
6) Until you get satisfaction from Bosch, the Bosch device gives precise menasurements that can be entered into a Pythagorean calculator online, which defeats the purpose of a jobsite tool: But you can access online calculator via cell phone while on jobsite.
http://www.analyzemath.com/Geometry_calculators/pythagorean.html
Feb 19, 2011 | Bosch DLR130K Laser Distance Measurer
My marksman never gives anything but an E reading
mine does that when battery is low or red light not bouncing back
Dec 23, 2010 | Black & Decker Distance Measurer with...
What's the rang on a cobra free 85
Any distance claims made by the manufacturer are pure fantasy. These are low-power UHF line-of-sight radios -- don't expect more than 1/4 mile effective range from them under most conditions.
Bill B.
Nov 15, 2010 | Cobra FRS 85 (14 Channels) 2-Way Radio
I have a WRT300N router. I was wondering what the maximum distance that laptop with a WPC300N can be too still get a good signal?
Coverage
We tested the router’s coverage at different distances and with different obstacles. We measured the signal level in five points:
Point 1: Near the WRT300N
Point 2: At a distance of 4 meters without obstacles
Point 3: At a distance of 5 meters + two thin gypsum wallboards
Point 4: At a distance of 6 meters + one brick wall, about 30cm thick
Point 5: At a distance of 17 meters + one thin gypsum wallboard and one 30cm brick wall
Here are the results...
Nov 21, 2009 | Linksys WRT300N Wireless Router
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Aug 12, 2009 | Leica Disto A6 Laser Distance Meter
Need error code information for 1995 Ford Aerostar minivan
Code#53: throttle position sensor high voltage. #85: canister purge failure. 36: (CSI) flow low or low revolutions per minute increase.
Jun 06, 2009 | 1995 Ford Aerostar
Retail Supplies Logo
292 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
