Question about Bayco Night Stick NSP-1136 LED Night Stick Flashlight
How do i open the night stick to add batteries?
  • 2,509 Answers
Already answered previously
Posted on May 14, 2014
What possible way can check to tell if my overnight battery drain is due to the diode sticking? Is there a test or a tip you could offer? The battery is new and the alternator tested ok.
A diode doesn't "stick". Either one of your circuits is using battery overnight, the battery is defective, or it's not charging.
Assuming the battery is "good", pull all of the fuses overnight. If it's good in the morning, put all the fuses back in, and next night leave one in. Next night, the next fuse, etc.
Once you know which circuit is draining your battery, you can troubleshoot further.
Sep 15, 2015 | 2008 Pontiac G6 GT
My 2005 Honda Accord radio dies intermittently followed by the battery dying.
Try disconnecting the battery at night or when not using if it does not drain flat go back to another auto shop that can find the fault, Check the obvious such as the boot light sticking on or the glove box light sticking on even remove these bulbs to eliminate,
Jun 09, 2014 | Vehicle Parts & Accessories
How do i open the light?
The side clips off
see here (scroll down page) and thank you to webbikeworld for the excellent review
I think I'll buy one for myself! Bayco Nightstick Flashlight Review
May 13, 2014 | Bayco Night Stick NSP-1136 LED Night Stick...
Need to add transmission fluid to 5 speed manual transmission on 1992 Toyota Celica
Open the hood up. You will find two different types of sticks, one near the alternator to the belts side, which is yellow or white colored and one on the battery side. It is orange colored, round small cup like dip stick, secured with a safety lock on it. Press the lock a side with your thump and take the stick out. When you push the stick inside it will sit in place firmly with a click sound.
You can add the Automatic Transmission Fluid (ATF) here.
Nov 25, 2013 | 1992 Toyota Celica
2007 gmc 1500 draining battery through the night, with a brand new battery
Have the alternater checked. The voltage regulator may be sticking and leaving an open circuit.
Feb 10, 2012 | 2007 Chevrolet Silverado 1500
The power steering fluid in my 1988 subaru DL is leaking out-somewhere. I have to fill it with a whole bottle once a week. Can anyone tell me--are there gaskets or rubber seals that fit inside the pump?...
There are "O" rings "everywhere" in hydralic, (sterring & Transmission) systems. Before spending hundreds, spend about $30.00 on some investigative/diagnostic tooling. You can buy an economical "UVL" (ultra violet light) battery operated from between $19.99 - $26.99 at most stores. invest in a small vial of "universal UV" fluid that mixes with oils & freons. Add an ounce, when you add your fluid. When the fluid is low, go out at night, open the hood (or turn your garage lights off) & check all connections with the Ultra Violet "teat" lamp.......It ( the problem) will stick out like a sore thumb. Benefit, You will have the tools for future use.
Sep 10, 2011 | Subaru DL Cars & Trucks
Washer machine filled up with water all night with door open? I have a mess of water in my basement and no water pressure.
If water comes into washer with no power to it and water valves are turned on then you have a bad water inlet valve in washer. Try unplugging washer and turn on water valves see if water comes in note may be small amount (but it does add up if it runs all night) if it does your water valve is bad..Replace.Sometimes the vales can stick open a little it is caused by buildup inside valves from minerals and other items in water....Note make sure if you replace valve that you have sediment screens in your water inlet lines on washer that will prevent items in water getting stuck in valves and keeping them open..If you need more help please ask if I helped you please vote Thanks and good luck
Feb 05, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Camera not turning on.
if it was working until you opened it.
It may be worth opening it again to check you didn't dislodge the ribbon cable for the mode switch.
if you could only half open it or had problems getting the diopter control back in (eyepiece focus) there is a screw under the stick on fascia that surrounds the eyepiece lens (not the rubber bit) use a scaple to peel it back...
best of luck
Nov 06, 2007 | Kodak EasyShare DX6490 Digital Camera
Bayco Night Stick NSP-1136 LED Night Stick Flashlight Logo
44 people viewed this question
Top Bayco Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Bayco Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
