Question about Sport & Outdoor - Others
Engine compression specs
What is the compression ratio on a 1988 suzuki 85hp outboard motor?
keemo68
  • 1263 Answers
SOURCE: mazda b2200 compression specs
those are average numbers and they are a little on the low but that is typical considering the age of the vehicle the compression should be 115 -120 psi.. hope this helps please rate this...thanks
Posted on Sep 24, 2008
dunglizard
  • 3 Answers
SOURCE: Fuel mix ratio for 115 hp force outboard engine
50:1 ratio
Posted on May 23, 2009
  • 23 Answers
SOURCE: I have a 85hp Yamaha outboard motor. It starts
sounds like the ground wire in the control box where your key switch is located is broken are disconnected. check the wiring harness plugs if it is unpluged are not pluged tight it will not shut off
Posted on Jun 19, 2009
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Overheat sensor keeps going off on our yamaha 85hp
Hello there:
when you changed out the sensor did you have the codes cleared from the computer brain this is common on outboards. contact your local dealer for further asistance .
best regards mike
Posted on Aug 09, 2009
1993 Suzuki 4hp 100.1 how much oil per gallon
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
Oct 01, 2016 | Clymer Suzuki 2-225 HP Outboards Includes...
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What should the compression be on a 1988 evinrude 185hp outboard?
The compression on your Evinrude outboard should be at least 100 with no more than 10% difference between cylinders. Keep in mind gauges can give very different results. Also, remember the test should be run when the engine is warm!
Hope this helps!
Jun 13, 2016 | Johnson Evinrude Ignition Kit, Digital,...
When doing a compression check on a 1988 Suzuki Samurai, what should it read on the compression gage?
With throttle held wide open... A good running engine should produce 140-160lb compression
Apr 25, 2015 | 1988 Suzuki Samurai
Fuel mix ratio for outboards
that depends on the age of the motor .if erroring it's better to have too much oil than noot enough sine that can seize an engine up
Jun 11, 2014 | Boating
Model 850
Year 1976
May 28, 2014 | Boating
How do you know if the shift cable is bad on an outboard suzuki 85Hp 1992?
Best and quickest is disconnect from the engine end and have some one run the box, also a broken cable will slide by hand from the connection end, and will sometimes come right out of the cable.
Sep 06, 2012 | Boating
I have a 1964 mercury merc 850 85hp boat motor.
I have the same motor, and the original manual.
The mixture is 50:1. Everything else will destroy your motor. Mercury has a toll free number, call there in case you still have doubts.
May 06, 2010 | Boating
I have a 85hp Yamaha outboard motor. It starts easily, but wont shut off (with the key or kill switch).
Jun 18, 2009 | Light Outboard Motor Boat Bass Fishing...
I am looking for a diagram of a 1977 evinrude 85hp engine - so i can work out how to remove the tilt rams from the engine to check if they are working correctly
Hi there, You can find all parts diagrams for Evinrude engines here: http://epc.brp.com Just ignore the email entry part and go straight to the database. They are listed by Brand, then year, then HP size. I checked for you and it has the 1977 85HP models listed there. Then just find the right subsection of the outboard and it will bring up exploded diagrams for your viewing!
Jun 15, 2009 | Boating
Sport & Outdoor - Others Logo
35 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
