Question about Icon Exercise & Fitness
What is the value of a Icon Image 5.0 Model IMSY50070
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
Tip
How to create a system folder in My Computer System folder like My Document...
How to create a system folder in My Computer System folder like My Document which appears in My computer are special folders which appear can not be deleted. Now if you want to create something like that, a folder which cannot be deleted!!!! . Here is how you do it to create a folder which cannot be deleted!!. It should work both in XP and VISTA.However a word of caution, If you don’t know about registry, either back up or don’t try this. I am not sure how to create a direct script for this so be cautious.
Step 1: Create a Unique Key
Open registry with “regedit” command on run window.
Navigate to HKEY_CLASSES_ROOT\CLSID\. Then right click and create a new key with value as {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Now set the default value of this key to the folder name you want to use. Now your path will look like ( I will call this as parent key throughout the discussion) HKEY_CLASSES_ROOT\CLSID\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Step 2: Add Custom Icon to the folder
Now create a sub key under parent key.
Name it as “DefaultIcon”.
Set the default value of this to the path of the icon image you want to use.
If you dont specify your icon, system will take default icon.
Step 3: Adding attributes
Under parent key create another key with name as “InprocServer32′
Set the default value as “shell32.dll”
Again at the same level create another folder as “ThreadingModel” and set its value as “Apartment”
Same way create another key (under parent level) at the same level with structure as \Shell\My Folder\Command
Set the default value here as “explorer /root,c:\Blog Data”
This has to be same which you gave when you created the first key.
Step 4 Adding Handlers
Under parent key, create another key as \ShellEx\PropertySheetHandlers\ {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Similar way another key is to added to parent key as “Shell Folder”
In this right click and create new binary value called as “Attributes” with value as 00 00 00 00.
Step 5: Settings to place in My Computer
Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
Then to \CurrentVersion\Explorer\MyComputer\NameSpace\
Add the parent key which in this case is {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}
Thats it, You are done. Try this carefully and I am sure there wont be any problem
on Dec 07, 2009 | Computers & Internet
Tip
Choppy image transitions when you view images by using the Slide Show
You experience choppy image transitions when you view images by using the Slide Show feature in Windows Vista and in Windows XP SP2 Windows Vista
1. Click Start , click Run , type regedit , and then click OK .
2. Locate and then click the following registry key:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows Photo Gallery\SlideShow
3. On the Edit menu, point to New , and then click DWORD Value .
4. Type WinSATScore , and then press ENTER.
Right-click WinSATScore , click Modify , click Decimal , type the value that you want in the Value data
box, and then click OK .
Note To start the Slide Show feature by using different resolutions, type one of the following values in
the Value data box, as appropriate for your situation:
5
• For a resolution of 1200x1000 pixels, type 300 .
• For a resolution of 1600x1200 pixels, type 400 .
• For a full-screen resolution, type 500 .
Exit Registry Editor.
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
What is the best treadmill brand?
1) Weslo Of all the Icon brands, Weslo treadmills are the least expensive, and in fact are typically the lowest priced of any treadmill regardless of manufacturer. They are entry-level machines intended for use by beginners and walkers that do not engage in a more demanding workout. They lack the power of more expensive brands and are built with smaller running areas. And warranties are typically no longer than 90 days.
In the Weslo line, the Weslo 400 CS treadmill sells for under $400. It is consistently picked as one of the top budget treadmill models.
2)Image
Image is another brand of treadmill produced by Icon Fitness. This line is slightly more expensive than Weslo, but is still considered a budget machine, typically selling for under $1000. Many experts feel that Image treadmills offer the best value for the average person. The only drawback is the warranty, which is only 90 days on many Image models.
The Image 1200 treadmill has a 2.0 hp continuous duty motor that provides a maximum speed of 10 mph. The platform can adjust to inclines from 0-10%. It is a great choice for those runners on a bit of a budget and for those who want to spend $1000 or less. The Image 10.6QL was ranked among the top five treadmills by U.S. Consumer Reports. It has six programmable workouts and also allows you to determine your speed and incline based on a heart rate monitor. It is IFIT compatible, which means you can connect to the Internet to access online workouts. It costs around $1400 and is folding for convenient storage.
3) Proform
Proform treadmills by Icon provide shoppers with perhaps the most comprehensive options in exercise equipment. Budget models start at $400 and the overwhelming selection continues up the spectrum to several mid priced models that fall in the $1000 to $2000 range. The Proform 795SL treadmill sells for under $1000 and is often a top pick among consumers and fitness experts. The LX 660 sells for under $600 and has plenty of features for a budget treadmill. Like many of the budget treadmills, Proforms often have a less than stellar warranty, typically 90 days.
4) NordicTrack
There are literally dozens of different NordicTrack treadmill models produced by Icon. They range in price from around $800 for a NordicTrack C1800 to $2000 for a 7500R model. Many fitness experts feel that consumers spend a bit more for the name brand when they purchase a Nordictrack treadmill. The machines often look very nice but may not always offer the best buy as some people have experienced problems with reliability. All models typically come with a heart rate monitor, but some of the less expensive models offer a 1.5 hp motor and a smaller platform, often around 50".
5) Reebok
Reebok treadmills also depend on name recognition to help attract buyers. Models often look nice and have plenty of features but have been known to be less durable than other brands. It is important to note that Reebok home treadmills are not made by the same company as the commercial models found in fitness clubs.
Please vote.
Thanks
George
Jan 12, 2011 | Proform 695 LT Treadmill
How do I shoot images in JPEG format inste4ad of Nikon format?
Press the image quality button repeatedly to cycle through the following values: NORMAL, FINE, HI, RAW, and BASIC. The image quality button is the topmost button in the cluster of buttons just above the speaker on the left side of the camera, marked with a sort of fan-like icon spreading from left to right.
Apr 28, 2010 | Nikon Coolpix 5700 Digital Camera
How to delete image controls
I am creating a windows mobile 6.1 application in VS2008 and I am creating a custom control that will use the picture box control. I expose the image property of the picture box by using a property tag. After compiling the code and adding the control to my project's form, the picture box image is initially blank but if I set it I must do it via the open dialog box (same as if just using the regular picture box). The problem is when I want to delete the image (if I made a mistake and do not want to include the image just have a blank picture box, it does recognize that the delete key was pressed in the property field. The only access to change the value is via the open dialog box and that requires a file to be selected. Attached is a code snippet of the property tag for to expose the image. Any help is greatly appreciated.
1: 2: 3: 4: 5: 6: 7: 8: Public Property Position1Picture() As Image Get Return picPosition1.Image End Get Set(ByVal value As Image) picPosition1.Image = value End Set End Property
Nov 12, 2009 | Dell Dimension 2400 PC Desktop
I can't find how to graph absolute value function.
Here how you do it taking as exemples y1=x^3 -5 and y2=abs(x^3-5)
Turn calculator ON by pressing [AC/On] . Use arrows to select [Graph] icon and press [EXE]
On line Y1= enter X[^]3 -5 [EXE]
On line Y2= press [OPTN] [F5:NUM][F1:abs] [(] X [^]3 -5 [)] [EXE]
The graphs will be drawn one after the other. You might have to adjust the window limits.
Here is an ouput drawn on another calculator.
For negative values of the x-variable, Y1 has negative values, while in the same range, Y2 has positive values, equal and opposite to those of Y1. In that range, Y1 and Y2 are symetric of each other with respect to the X axis.
For positive values of the x-variable, Y1 and Y2 are identical.
Hope it helps
Jan 30, 2009 | Casio CFX-9850G Plus Calculator
Red ghosting on images that are not closeup
1. Power off -- let bulb cool.
2. Display - 5 - VOL+ - Power (in quick sequence) to display service menu.
3. Go into the user menu and set auto revision back to auto.
4. Put an image on the screen that shows the problem. I always found the edges of a 4:3 aspect ratio signal displayed the ghosting very well on my set.
5. Use 2 to scroll through the categories to find D GM TG
6. Use 1 to scroll through items in D GM TG to find V POS D
7. Write down current value.
9. Use 3 and 6 to change the value to minimize the ghosting. You should only need to move it up or down a value or two.
10. Press Mute - Enter to save the changes.
11. Power off and let the bulb cool.
Jun 25, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
SMALL ICON APPEARS ON THE SCREEN (TOP L/HAND CORNER)
Hi there
Have you tried pressing the Menu button when this happens ?
Dec 12, 2007 | Office Equipment & Supplies
Exercise & Fitness Logo
101 people viewed this question
Top Icon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
